22"s? And lowering questions
I have 2" front hubs and belltech struts with 1" taken out of them. I also have a 5" axle flip in the rear, so 3/5 total. I have 22x9 ltz reps with 305/40/22 tires. They rub a little when turning lock to lock, and when I hit a large dip in the road.... I feel that a 285 tire wouldn't have this issue, or if I had stiffer front springs.
I am running 265/40/22 front and 285/40/22 rear with Belltech 5.5/8 drop. If you just want to level the truck then toss on a set of 2" shackles and remove the rear 1" block.
formerly 04 Rooster (2013-12-10)
I have 22s on 305 tires. Lowered up front with McG's spindles and only shackles in the back. the back needs to come down some more but I have zero issues with rubbing. I plan to remove the rear blocks to bring the back down more.
The 5/3 drop from DJM is really nice. I used that the 1st time I dropped mine. and towed all the time, no notch needed. My 2cents!!
GXPJAY
02-13-2022 08:15 AM
GXPJAY
11-05-2015 06:49 AM
