22"s? And lowering questions
Old 09-05-2014, 11:04 AM
StreetGliderX's Avatar
Default 22"s? And lowering questions
2007 nnbs rcsb what's the best way to lower it mostly to level nothing so extreme I need notches or tub work. And who runs 22 inch wheels on them?
Old 09-05-2014, 05:03 PM
FFDP's Avatar
If you just want to level it out, 2in lowering shackle is the way too go.
Or do a 2/4 drop, both should not require notches or tub work.
Up front your tire size might become an issue though, too big and they will rub.
Old 09-13-2014, 11:50 AM
Ryan Mills's Avatar
I have 2" front hubs and belltech struts with 1" taken out of them. I also have a 5" axle flip in the rear, so 3/5 total. I have 22x9 ltz reps with 305/40/22 tires. They rub a little when turning lock to lock, and when I hit a large dip in the road.... I feel that a 285 tire wouldn't have this issue, or if I had stiffer front springs.
Old 09-16-2014, 11:04 AM
FormerVendor
TheSuspensionSource's Avatar
I am running 265/40/22 front and 285/40/22 rear with Belltech 5.5/8 drop. If you just want to level the truck then toss on a set of 2" shackles and remove the rear 1" block.
Old 09-19-2014, 04:04 PM
formerly 04 Rooster (2013-12-10)
09 Rooster's Avatar
I have 22s on 305 tires. Lowered up front with McG's spindles and only shackles in the back. the back needs to come down some more but I have zero issues with rubbing. I plan to remove the rear blocks to bring the back down more.
Old 09-19-2014, 05:15 PM
1lowgmc's Avatar
7/10 drop, 265/40r22. Don't go any less than 4/7. Otherwise its a waste of money.
Old 09-19-2014, 07:13 PM
So.cal Wrk Sled's Avatar
The 5/3 drop from DJM is really nice. I used that the 1st time I dropped mine. and towed all the time, no notch needed. My 2cents!!
Old 09-22-2014, 03:24 PM
FormerVendor
3/5 works too.
Old 09-22-2014, 04:53 PM
Jason Z69's Avatar
With a 3/5 u can run a bigger tire than a 2/4. Just not as wide.
GXPJAY
02-13-2022 08:15 AM
GXPJAY
11-05-2015 06:49 AM
spiritfish
08-23-2015 09:58 PM
USMCvet0311
08-01-2015 07:45 AM
Quick Reply: 22"s? And lowering questions
