2011 Silverado kooks headers
Old 06-08-2016, 02:43 PM
Turd Gen Guy
1nasty86's Avatar
Default 2011 Silverado kooks headers
Finally made the leap to buy some 1 3/4 kooks headers and the catted y pipe for my truck... for anyone who has done this install how hard was it and what all did you have to remove? i understand spark plugs, dipstick, etc... anything else? here is a picture of the daily
Old 06-08-2016, 02:45 PM
FFDP's Avatar
Transmission cross brace needs to be removed on the one side to slip the whole Y-pipe assembly out. Support the transmission from the bottom with a jack or something similar.
Remove the o2's after it's on the ground or before, doesnt really matter.
Old 06-08-2016, 02:50 PM
Turd Gen Guy
1nasty86's Avatar
the kooks y pipe isnt one piece i figured i could install it with the cross brace still installed.... use something to cut the old y pipe out of the way... well dang
Old 06-08-2016, 03:01 PM
FFDP's Avatar
If you want to hack it up go ahead but I just assume leave the stock unit in one piece. Just in case you wish to keep it or try to sell it. It's 4 bolts to drop it, takes only minutes with a impact.
Old 07-31-2016, 02:24 PM
Turd Gen Guy
1nasty86's Avatar
Headers are finally in.... now to wait for it to cool off some and install them
Old 08-23-2016, 11:43 AM
jwdominick's Avatar
and? how was the install?
Old 08-24-2016, 11:20 PM
HP52TA's Avatar
Hey man, how's the Camaro running? Still have it?
Not sure if your old exhaust seen any winter's but if so, you will have a tough time removing the three nuts off the stock y pipe to mainfolds. I wasn't looking to save the old y pipe when I did mine so cut the y pipe about 3" below the joint on both sides, then just unbolted the mainfolds. That was after two days of soaking those studs and nuts with penetrating spray to no avail.
Even with the hi-flow cats you will have to disable the codes for your rear o2 sensors once installed, unless you want to live with them.
What are you planning to run for muffler?
Old 08-25-2016, 06:01 AM
HP52TA's Avatar
One other thing you will need, spark plug wire heat sheild sleeves. Wires end up being real close to a few header primaries.
Old 08-25-2016, 09:37 AM
Idryfly5's Avatar
This ^^^
I run these.
DEI Protect-A-Boot Kits - Set of 8 (Choose Color) [DEI-PAB] - $66.15$53.95 : MarylandSpeed.com- Your First Stop on the Way to Performance!
Old 09-01-2016, 02:15 PM
Turd Gen Guy
1nasty86's Avatar
Install went great as far as I can say.... no broken manifold bolts so that's always a plus.... the three bolts that hold the pipe to the manifold gave us some fits but a 3/8 ratchet and a cheater bar worked great... as far as dropping the crossmember I didn't bother and just cut it in places that could be easily welded back up.. as far as the headers go I didn't have to remove the steering shaft but I did remove the dipstick and the kooks y pipe clears the 6l80 with ease and I already have the dynomax ultraflo catback installed but from 1500-1900 I'm getting some serious drone so I'm gonna install a vibrant ultra quiet resonator just before the exhaust tip and see how that works
Quick Reply: 2011 Silverado kooks headers
