2011 Silverado kooks headers
Turd Gen Guy
the kooks y pipe isnt one piece i figured i could install it with the cross brace still installed.... use something to cut the old y pipe out of the way... well dang
Hey man, how's the Camaro running? Still have it?
Not sure if your old exhaust seen any winter's but if so, you will have a tough time removing the three nuts off the stock y pipe to mainfolds. I wasn't looking to save the old y pipe when I did mine so cut the y pipe about 3" below the joint on both sides, then just unbolted the mainfolds. That was after two days of soaking those studs and nuts with penetrating spray to no avail.
Even with the hi-flow cats you will have to disable the codes for your rear o2 sensors once installed, unless you want to live with them.
What are you planning to run for muffler?
Turd Gen Guy
Install went great as far as I can say.... no broken manifold bolts so that's always a plus.... the three bolts that hold the pipe to the manifold gave us some fits but a 3/8 ratchet and a cheater bar worked great... as far as dropping the crossmember I didn't bother and just cut it in places that could be easily welded back up.. as far as the headers go I didn't have to remove the steering shaft but I did remove the dipstick and the kooks y pipe clears the 6l80 with ease and I already have the dynomax ultraflo catback installed but from 1500-1900 I'm getting some serious drone so I'm gonna install a vibrant ultra quiet resonator just before the exhaust tip and see how that works
