TPS Code P0121
Old 02-28-2012, 05:25 PM
Nekroman's Avatar
Default TPS Code P0121
Hey dudes so my 2008 Silverado threw this code last night, P0121 TPS throttle position sensor. Anyways, i called a local chevy dealer and i explained to the tech what was happening. I had an idle of 1,500RPM while in park as soon as i shifted into drive or reverse it would be normal. I also asked if i was able to change out the TPS, he said no. He told me that i needed to replace the entire TB assembly. I just want clarification on this issue. Am i going after the right problem or is it something else wrong with the truck? And also, is the tech correct on me having to buy a new TB? thanks guys!
Old 02-28-2012, 05:53 PM
Robert91RS's Avatar
Tech was telling the truth but you can try cleaning the TB first if you like.
Old 02-28-2012, 06:56 PM
Nekroman's Avatar
Thanks for replying dude, I actually did clean it out. I didnt use a cleaner but I just wiped it down with a rag. Funny think is after I cleaned it, the RPM's shot up to 1,500 and I couldnt bring her down to a normal idle.
Old 02-28-2012, 08:48 PM
Robert91RS's Avatar
Try putting a few miles on it and see if the high idle and SEL clear themselves.
Old 02-28-2012, 10:33 PM
Nekroman's Avatar
Kool thanks Rob, I apprecite the input.
Old 02-29-2012, 09:29 AM
BrutalSierra's Avatar
yeah unplug your battery your battery for 30mins. Start your truck and push emergency brake all the way down. Put in drive with ac off and let idle for 5 mins. Then do the same with ac on for 5 mins. Then after 200 miles max it should have relearned its settings. If that doesn't solve your problem you can buy a LS7 TB off ebay for 150.
Old 02-29-2012, 01:49 PM
Robert91RS's Avatar
Nekroman, I forgot to ask you how many miles you have on that rig. The throttle body is covered by the 5yr 100k mile warranty. Im sorry I forgot to tell you that.
Pimpinpete
43
12-22-2017 08:13 AM
00loudchevy
12-03-2015 05:54 PM
Avalanche2002
11-30-2015 07:31 AM
bearden86
26
11-15-2015 03:58 PM
Pimpinpete
09-08-2015 07:39 PM
Quick Reply: TPS Code P0121
