Parking Brake Cable Rubbing Through Shock
Old 07-07-2023, 08:31 PM
'12 AWD Platinum Escalade
wardlws's Avatar
Default Parking Brake Cable Rubbing Through Shock
This probably only applies to GMT900 Escalade, Tahoe, Yukon, and Suburban trucks, but I finally fixed my parking brake cable rubbing on my left / driver's rear shock. It has been rubbing since I bought the truck, but got worse when I lowered it.
If you have the same issue, it was an easy fix. I noticed that the right / passenger brake cable had plenty of slack and the left / driver brake cable need about an inch more slack. All I had to do was loosen the tension nut on the tensioner, disconnect the cables from the tensioner, and swap the two brake cables in their mounts (top / bottom). Move the longer cable up, and the shorter cable to the bottom mount... and all fixed.
This last photo is after I switched the two cables.
Hope this helps somebody... Also, I'm curious if anyone else had the blue-ended cable on the top instead of the bottom. Maybe they just didn't put mine together right at the factory.
terravast4
11
07-05-2021 02:36 PM
40series
11-25-2015 09:04 PM
marlboroman71818
05-17-2012 09:41 PM
2xcapers
02-07-2012 07:39 PM
2006 Silverado
08-16-2009 10:19 AM
Quick Reply: Parking Brake Cable Rubbing Through Shock
