Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
Go Back   PerformanceTrucks.net Forums > GENERAL MOTORS SPECIFIC FORUMS > GMT 900 Trucks
Sign in using an external account
Register Forgot Password?
Register Albums FAQ Members Calendar Search Today's Posts Mark Forums Read VendorsGarageUsed CarsStore TSBs & Recalls
Welcome to PerformanceTrucks.net Forums
LinkBack Thread Tools Search this Thread
Old 12-06-2009, 09:44 PM   #1
Trader Rating: 0
Default 09 GMC burning oil
I have a 2009 GMC RCSB 4X4, 5.3 iron block with AFM, 4 speed auto with 4.10 gears. Every once in a while when I start it up hot a cloud of blue smoke appears out the exhaust. I have ARH longtube headers (thanks Allgonoshow) with highflow cats, Magnaflow cat-back, GMPP cold air intake and a Wester's tune. It was smoking before I installed the mods.
Well, it has only 1,550 miles on it and it has burned one quart of oil. I took it into the dealer last week and they have started an "Oil Consumption Record" on it. I didn't expect much at this early stage and basically just wanted it on record as using oil. Does anyone know of any TSBs or anything about the new 5.3s with AFM using oil? I've read about other 5.3s using oil on other forums and the dealer replacing the lifters. Seems more like a valve guide or seal issue to me. AFM is turned off now with my tune.
The good news is they didn't say a word about my headers or mods and seemed to really be concerned about the oil use. I had them change the oil to Mobil 1 5W30 and K&N oil filter while it was there. I'm supposed to monitor the mileage and oil use and bring it back for them to top it up.
Anyone familiar with this issue?
09Jimmy is offline   Reply With Quote
Old 12-07-2009, 06:32 PM   #2
Trader Rating: 19
scooter k's Avatar
There is a PI about over aggressive lifters and update driver's valve cover. I've seen one with this problem. One of the back lifters was over oiling and spraying it into the driver's valve cover baffle. The valve cover has been redesigned because the drain back holes couldn't drain oil fast enough and the fixed pcv orfice was sucking oil out and burning it. Seen a couple too with valves with nicks in them but those were on 07 models.
They just updated the PI December 2 so engineering should have a permit fix for it soon.
__________________
scooter k is offline   Reply With Quote
Old 12-07-2009, 11:56 PM   #3
Trader Rating: 31
We had a customer come in complaining about using oil, about the same amount yours is on a 09 very closely optioned to yours. He had about 2000 miles when he first started to notice it. He monitored it for a month and it used an additional quart by 3000 miles. Then he made a trip to colorado pulling a trailer to pick up a 35 dodge he had purchased. Simply told him to dog the bejesus out of it on the way up and back. He said it started running better and better the closer to 4000 miles it got on the trip up. Drove the **** out of it pulling grades going through new mexico on up into Durango and silverton colorado. Then at times drove the truck easy and babied it for short distances. It used less and less oil over the course of the trip as the mileage increased. After returning home from his trip we changed oil to get a baseline on it. So far after 3000K miles since changine oil after he got back home it has not used a drop since the trip. He pulled a 25 ft flatbed trailer on the way up and loaded it up with a 35 dodge truck to make the trip back. Pulled it fast,slow, foot to the floor part throttle and everywhere in between on this trip. Not saying this would help yours but it did help this one.
01WS6/tamu is offline   Reply With Quote
Old 12-08-2009, 12:44 AM   #4
Trader Rating: 1
Dewey's Avatar
i've always been told to stick to conventional oil for the engine break in period, for exactly this reason... could improper seating of the rings be causing this?
__________________
99 Sierra Custom - For sale - PM me for details.
Quote:
Originally Posted by Phantom View Post
remember the first time you busted a nut? yeah, kinda like that
Dewey is offline   Reply With Quote
Old 12-08-2009, 12:59 AM   #5
Trader Rating: 5
bad intentions's Avatar
i have an 09 and changed my oil after the break in to royal purple i have not noticed anything but will be checking.
__________________
01 silverado 4.8 stock 15.9... Keeping it stock 57 thousand miles...
02 SS camaro restore and boltons for now!!!
bad intentions is offline   Reply With Quote
Old 12-08-2009, 11:31 AM   #6
Trader Rating: 0
Thanks for the reply. You know, I kinda wondered about the hose that goes from the passenger side valve cover to the GMPP cold air intake. It doesn't have a PCV valve or a check valve in it and I thought it might be able to suck oil up into the throttle body. Maybe I should install a catch can in there and see what shows up?
Old 12-09-2009, 01:20 AM   #7
Trader Rating: 0
niugnep's Avatar
I have a copy of that, sent you a pm, if you want it e-mail me, can't post it here.
niugnep is offline   Reply With Quote
PerformanceTrucks
Ford F150
Paid Advertisement
Tags
53, 53l, afm, aggressivelifters, burn, burning, burns, colorado, gmc, gmt900, lifters, mobil, oil, pickup, problems, trucks
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
PerformanceTrucks.net and InternetBrands, Inc. are not affiliated with the Ford Motor Company
