Z71 clunk... what the hell is it??? - Page 2 - PerformanceTrucks.net Forums
Thread Tools Search this Thread
Old 07-26-2009, 09:06 PM   #11
2nd fastest 5.3 ECSB
trever1t's Avatar
I had it bad, replaced the yoke to the upgraded 'nickel' plated one but still had it. It was loud as hell and intermittent but would do it loudest when reversing then driving forward at low speeds.
I can't say i found the cure but as soon as I swapped out the front shocks (stockers) it disappeared and hasn't returned.
trever1t is offline   Reply With Quote
Old 07-27-2009, 09:01 AM   #12
Just out of curiosity, when you guys are having this "clunk", are you experiancing it on trucks with Step Bars on them? The reason I ask this, is because we have seen hundreds of cases and so many in fact that GM has a Tech Bulletin on Aftermarket Step Bars causing mysterious "clunk" sound resonating through the vehicle.
Or...is this "clunk" only heard when shifting from park to drive or reverse? If you guys will give me some detailed info, I'll try to help you out as best as I can.
Torque_Wrench is offline   Reply With Quote
Old 07-27-2009, 09:43 AM   #13
BigTex's Avatar
On my Z71, the clunk came from the overload spring making contact with the spring pack. Putting it into reverse / drive would cause the diff to rotate just enough to force the overload spring to rub the spring above it. The GM fix was to put a set of rubber sleeves over the ends of the overload springs. Fixed it for me.
BigTex is offline   Reply With Quote
Old 07-27-2009, 01:58 PM   #14
Neil 6.0's Avatar
Location: as far away from Koonerville as humanly possible
My HD was clunking when I bought it (used, April '08). Pulled the driveshaft out and smeared it and the tranny splines with Green Grease and it hasn't made a noise since. Tractor Supply and Academy usually have it, it's waterproof, high temp, lasts long time.
Neil 6.0 is offline   Reply With Quote
Old 07-27-2009, 06:44 PM   #15
skolman91's Avatar
Mine was taking off from a stop light, and sometimes when slowing down coming up to one, but not as much. didnt do it all the time either..
skolman91 is offline   Reply With Quote
Old 07-27-2009, 09:22 PM   #16
Seventhrelic711's Avatar
my cousin had this clunk...turns out it was his pittman arm, just wear and tear
Seventhrelic711 is offline   Reply With Quote
Old 07-28-2009, 01:17 AM   #17
11 Second Hall Moniter
AKlowriderZ71's Avatar
I had a clunk just as leaving stops that began after a routine rear diff service. Turned out that the tech used 75w-140 synthetic and thought it would be okay. Drained it, and switched back to 75w-90, and no more problems. Seems the thicker lube was causing the Gov-Loc to stick.
AKlowriderZ71 is offline   Reply With Quote
Old 07-28-2009, 08:44 AM   #18
It's obvious that from the numerous "clunk" comlaints, and fixes to the problem that not everyone has the same clunk. The "clunk" most commonly heard through the typical situation is either the Slip Yoke clunking or the Rear Spring clunking.
Like afore mentioned by BigTex, the GM fix if the urethane inserts to stop the sound from the springs. Now, however GM has a reccomended fix for the slip yoke by replacing it with the Nickel Plated yoke, tghis does not mean that it will work for the othert clunking complaints. I've replaced the Nickel Yoke many, many times ans some indeed come back witht he same problem and it seems the yoke didn't fix it. That's not to say that it's always the yoke making the noise, as you can replace the yoke and then a few weeks later, the clunking comes back and it can end up being a totally different culprit altogether.
Most commonyl the clunking culprit is a steering shaft, slip yoke, rear springs or aftermarket step bars. The step bars mount diffrently and they cause a popping or clunking because of binding on the mounts.
Thread Thread Starter Forum Replies Last Post
P0446 Avalanche2002 Tuning, Diagnostics, Electronics, and Wiring 7 11-30-2015 07:31 AM
Picked up a new Ride... cheyenne383 GMT 800 & Older GM General Discussion 9 11-13-2015 09:24 AM
2006 Sierra Z71- 4x4 to AWD...HELP!!!! StrokeTheLS GM Drivetrain & Suspension 2 09-29-2015 08:33 PM
LQ4/9 Swap in GMT400 Vortec Tahoe - Wiring Suggestions lxcoupe GMT 800 & Older GM General Discussion 2 09-23-2015 12:11 AM
Tags
2001, 2002, 2009, 4l60e, clunk, clunks, drive, loud, park, pop, reverse, shifting, sierra, slip, tahoe, yoke, z71
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
