Water Pump Leak???? - PerformanceTrucks.net Forums
Water Pump Leak????
LinkBack Thread Tools Search this Thread
Old 09-17-2007, 09:42 PM   #1
2001si3rr@'s Avatar
Default Water Pump Leak????
I was under my "New to Me" 2001 Z71 today and noted a couple things nothing major I hope, but anyway I thought I would ask.
I noticed a couple of drops of DexCool on the bottom of my water pump, and some small trails were the drops had fallen and worked there way down the front of the oil pan. I almost thought it was some sort of grease because they were not fluid like, they were little red-orange jel like drops. Is it normal for dexcool to jel up or is there something else going on?
2001si3rr@ is offline   Reply With Quote
Old 09-17-2007, 10:00 PM   #2
PT's Slowest Truck
budhayes3's Avatar
If it's coming from the front of the pump or the weep hole (if so equipped), then the pump itself is leaking. If not, it's very common for the gaskets (where the pump mounts to the block) to leak.
budhayes3 is offline   Reply With Quote
Old 09-17-2007, 10:02 PM   #3
If its a small leak and its not overheating its leaking from one of the gaskets. I have replaced the gaskets on my 02 suburban for that reason. My brother had the same problem but his was a smaller leak
adrenalinep is offline   Reply With Quote
Old 09-17-2007, 10:15 PM   #4
2001si3rr@'s Avatar
I think it might be leaking slightly, but have not pin pointed the source of the fluid yet(gasket or weep hole)
So, does dexcool jel up like this if it sits for awhile?
Old 09-17-2007, 10:31 PM   #5
terravast4's Avatar
My 05 had the same problem. I noticed the "jelly" in a crevice in the passenger cylinder head rarely did I see coolant on the ground it took about 6 mos. to figure out it was the gasket leaking.
terravast4 is offline   Reply With Quote
Old 09-18-2007, 10:54 AM   #6
Yogi Bear's Avatar
Yes, DexCool will gell when exposed to heat and air. That's why it so important to keep the level up in the reservoir tank. If the tank goes dry, and you get air in the coolant in the motor, it will gell there too. You need to find the source of the leak and fix it.
Yogi Bear is offline   Reply With Quote
Old 09-18-2007, 06:46 PM   #7
2001si3rr@'s Avatar
Sounds good... Thanks for the help guys..
Old 09-20-2007, 09:25 PM   #8
2001si3rr@'s Avatar
Took the shroud and clutch fan off today, and found a good amount of fluid coming from the weep hole. So, I drained the cooling system and removed and replaced the pump with a new unit from NAPA. Also replaced the thermostat to be on the safe side, then replaced all the old DexCool with new pure DexCool and distilled water. Got everything back together and running good. Funny thing is I think my a/c gets colder now???
Old 09-21-2007, 09:28 AM   #9
Yogi Bear's Avatar
Sounds like you got it. Glad to hear it!
Thread Thread Starter Forum Replies Last Post
About to burn the truck down creekrat Tuning, Diagnostics, Electronics, and Wiring 2 09-10-2015 01:59 AM
Any simple answers? custm2500 Tuning, Diagnostics, Electronics, and Wiring 7 09-08-2015 06:53 PM
Hotwire kit and 340 pump slowswb GM Parts Classifieds 1 09-05-2015 03:27 PM
2007 GMC Sierra SLT Lifted the owl Trucks and SUV Classifieds 0 09-04-2015 05:09 PM
Do all the 72000 Air Lift kits come on a few times while driving? mr03silverado GM Drivetrain & Suspension 0 09-03-2015 12:43 AM
Tags
2001, 2004, be, chevy, hole, leak, leaking, normal, orange, pmp, pump, small, tahoe, water, weep
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
