truck wont start. help me out guys
Old 09-05-2010, 07:02 PM
KickinAssAndTakinNames
colekill's Avatar
Default truck wont start. help me out guys
so i have been having some battery issues due to the fact that its not my DD anymore. got a new battery today truck started perfect, shut it off and about 20 minutes later i go to leave and it will turn over, crank, then immediately die. Now its done this several times in the past, when the battery has been completely dead. i just let it sit for an hour then it cranks and runs like nothing ever happened. i allays just figured the computer needed some time to pull itself back together, and figure out what it was supposed to be doing. but this time its been about 4 hours and it still wont start.
i pulled a vacuum line to smell for gas to see if it was flooded, not the case.
TB and everything is clean.
its getting spark, and gas.
any ideas, or something else i should check?
oh and its the 99 in my sig
Old 09-06-2010, 11:37 AM
colekill's Avatar
Bump^^^
Old 09-06-2010, 12:49 PM
Formerly 99-2door-08/30/2010
Is the security light flashing when this happens?
Old 09-06-2010, 05:34 PM
colekill's Avatar
it blinks security when the door is open but not when its closed. however when i close the door and look it with the factory alarm it blinks security again.
here's a video of what its doin.
Old 09-06-2010, 07:30 PM
gs7793's Avatar
my dads truck did that, and it ended up being the cam sensor, but his is a f250 disel.....thats as much help as i can give, idk ive never seen a gas truck do that
Old 09-06-2010, 07:49 PM
colekill's Avatar
I am on the original cam sensor. About 175k miles
Old 09-06-2010, 08:12 PM
sixltrbtr's Avatar
will it start and run if you give it some throttle?
Old 09-06-2010, 08:30 PM
Krazy Ken's Avatar
Very stupid question but is your battery cables tight and not gummed up? I had a ghost problem like that because i had the 12v starter wire on the back of the starter come loose and cause an intermitent starting problem. I felt like a freakin idot once i figured it out.
Old 09-07-2010, 01:01 AM
colekill's Avatar
If I give it some throttle it sometimes revs a little higher but still dies the same way.
The batterie cables appeared fine when I put the new batterie on but I'll double check them and ground connections tomorrow.
Old 09-08-2010, 04:06 PM
colekill's Avatar
bump for new ideas
Quick Reply: truck wont start. help me out guys
