tom henry racing silverado
i posted the ton henry website, but more grip took it out and edited my post??
i dont know why. im going to pm him and ask him. do a search for tom henry. it should pop up.
The Hot Rod Truck Headquarters, Tom Henry Racing presents the Supercharged Silverado.
Tom Henry Racing, your hot rod truck headquarters, sells the "Supercharged Silverado" a modified version of the Chevrolet's full-sized Silverado pickup truck. The THR Supercharged Silverado is a "tuner truck" aimed at the hardcore, high-performance truck enthusiast. With the emphasis on performance and value, THR Silverados are basic, half-ton, standard cab, short box pickup trucks fitted with either 450 or 500hp, supercharged engines and a package of performance-
-oriented accessories such as 20-in tires and wheels and a stainless steel dual exhaust system.
At Tom Henry Racing, we think the THR Supercharged Silverado is a great package, but don't take our word for it. Read what some in the automotive press say:
"One last 18-wheeler went by, I tromped the gas and cranked the wheel left. As I finished the turn, I just about floored it. Whoa! This sucker has some mid-range torque! The big Goodyears spun and the truck began to powerslide. I lifted just slightly for it to hook, straightened the wheel and held about three-quarters throttle until it shifted to second, then I buried it, again. Working past 5000 rpm, with my foot on the floor, you could hear that Magnuson blower whine and the low-restriction exhaust bellowed its V8ness, loud and clear. I looked at the speedometer.
One word, tells all about this truck.
Under the hood is a supercharged Chevy V8.
"It's a big, red, rumbling, rubber-burning, hot rod, pick-up. What's not to like?! Said another way: one subjective observation about THR Supercharged Silverados is: they'll effortlessly smoke the tiresŠeven with their locking diffs and 20-in. Goodyears.
--Truckin' Magazine
--Truckin' Magazine
2005 THR Supercharged Silverado
General:
Front-engine, rear-drive, 3-passenger, 2-door, pick-up truck. EPA vehicle class: full-sized truck. Manufacturing location: Fort Wayne, Indiana and Pontiac, Michigan, USA or Oshawa, Ontario, Canada. Modification facility location: Bakerstown, PA, USA.
Equipment and Prices: Chevrolet Silverado, 1500, regular cab, short box
Base manufacurerÕs suggested retail price: $20215.00
Factory options on truck: color-keyed grille surround, $145; LR4 Vortec 4800 engine, $945; locking differential, $295; 3.73 axle ratio $50; color-keyed carpeting and floor mats $100; soft tonneau cover, $280; power locks, $50; power windows and mirrors, $738; custom cloth trim w. 40/20/40 bench seat, $285; destination charge $850; option discount for five-speed manual -$500
Tom Henry Racing options on truck: base THR Silverado package, incl. stainless steel chambered exhaust, 20-in. American Racing Torque Thrust wheels, Goodyear P275-55R20 Eagle LS tires, tailgate spoiler, Houndstooth seat inserts and THR head rests, silver-faced Escalade gauges, THR serial number plates, THR windshield header and glove box sticker, $6995; Magnuson Radix Supercharger system, $5700; hood stripes, $750; pickup bed rug, $450
Suggested retail price, as delivered:
$37510.00
Entertainment:
Delco ETR AM/FM stereo radio w. 4 speakers.
Engine:
OHV 90” V-8, iron block, aluminum heads, aluminum intake manifold, aluminum supercharger and cast iron exhaust manifolds.
Bore x stroke: 96-mm. x 83-mm
Displacement: 297 cubic inches/4.80-liters
Valve gear: roller hydraulic-lifter camshaft, pushrods, roller rocker arms, 16-valves, 2.00-in intake, 1.56-in exhaust valves.
Ignition:
Distributorless, inductive, crank-triggered, individual coils.
Engine and emissions controls:
General Motors Powertrain/Delphi sequential electronic port fuel injection. GM/Delphi/Magnuson engine controls w. feedback spark and air/fuel ratio control, 3-way catalyst, EGR and OBD2 emissions controls diagnostics.
Lubrication system: pressure w. full-flow oil filter
Electrical system: 14v
Exhaust system: dual down pipes and dual catalytic converters into short single pipe into dual stainless-steel, chambered mufflers w. dual, polished stainless-steel outlets.
Power: (est) 455-hp SAE net@5750rpm
(obs. at rear wheels, SAE-corrected) 373@5750rpm
Torque: (est) 472-lb/ft SAE net@4500rpm
(obs. at rear whl., SAE-corrected) 387@4500rpm
Rev limit: 6500 rpm.
Drivetrain (base)
Clutch: Single plate, dry
Transmission: New Venture Gear, NV3500 5-spd. manual, aluminum case, steel internals.
Transmission ratios: 4.02, 2.32, 1.40, 1.00, 0.73 and 3.55 reverse.
Salisbury live axle w. 8.6 in. ring gear with locking differential
Final drive ratio: 3.73:1.
Chassis/Body
Structure: steel ladder-type frame, steel cab, steel pick-up box.
Exterior: Stamped steel.
Suspension
Front: Independent, short-arm/long-arm. Stamped-steel control arms. Coil springs, stabilizer bar and gas-pressurized, hyd. shock absorbers.
Rear: Live axle. Semi-elliptic, variable rate, two-stage, multi-leaf springs and gas pressurized, hyd. shock absorbers.
Steering:
Hydraulic power-assisted, rack-and-pinion steering.
Brakes
Type: four-wheel, hydraulic disc brakes, vacuum power-assisted with ABS and dynamic rear proportioning (DRP).
Front: floating, two-piston calipers. Vented, 12.0x1.14-in. rotors. |
Rear: floating, single-piston calipers. Vented, 12.8x0.78-in. rotors.
Wheels/tires
Wheels: aluminum American Racing Torque Thrust 8.5x20-in
Tires: Goodyear Eagle LS P275/55R20
Interior:
40/20/40 split-bench seat, driver and passenger, 2-way manual adjustable. 3-point, manual, shoulder/lap belts. Dual air bags.
Cargo Box:
56.9 cuft.
Weights and measures
Wheelbase: 119.0-in.
Length: 203.2 in.
Width: 78.5 in.
Height: n/a
Front track: n/a
Rear track: n/a
Curb weight: 4520 lbs
General:
$37510.00
Entertainment:
Engine:
Ignition:
Drivetrain (base)
Chassis/Body
Suspension
Steering:
Brakes
Wheels/tires
Interior:
Cargo Box:
56.9 cuft.
Length: 203.2 in.
Width: 78.5 in.
Height: n/a
Front track: n/a
Rear track: n/a
