squeaking when let off brakes
Old 05-24-2016, 08:19 PM
40series's Avatar
Default squeaking when let off brakes
hey guys i put nice EBC brakes and a new caliper on the left but the brakes squeak on left when i let off brakes
what could this be from ?
Old 05-24-2016, 08:25 PM
FFDP's Avatar
Take the tire off and push the brake while you look at it, then see what makes the noise.
Grease anything that is needed, be it the slides or the metal tins.
Old 05-24-2016, 08:32 PM
40series's Avatar
Default will do
will do
Old 06-01-2016, 07:38 PM
40series's Avatar
Default inspected rt brakes
i have un even pad wear on the right side caliper one pad was more thin than the othere and these are new
EBC pads too , i greases the d=shims with bearing grease and the sueak came back same night ..... i dont know what is causing this ...?
Old 06-02-2016, 12:51 AM
01SilveradoJakee's Avatar
There is a TSB from GM for the rear brakes from 99-06 and 07-13 for the rear brake slides and front brake slides. Their brake lube dries and locks up the slide. Go to napa and get the Purple Brake Grease (High heat formula ) and the issue is gone.
Old 06-02-2016, 10:21 PM
Wolftrk99's Avatar
Sounds like something is maybe hanging up on the right side.... Which pad is worn more the inner or outer.... You may need to replace the right caliper is youve already replaced the left....
Old 06-04-2016, 08:30 PM
40series's Avatar
Default replaced right caliper
replaced right caliper and its still squeeking and i put some bearing grease across shims latter still squeeks????
Old 06-04-2016, 09:06 PM
Wolftrk99's Avatar
Is the pad slide touching the rotor??
Old 06-04-2016, 10:15 PM
You also have to remember that the parking brake is inside the rotor . Did you clean and lube the parking brake assembly?
GMCtrk
05-26-2016 02:12 AM
Flewbyu123
05-20-2016 01:34 AM
lxcoupe
05-08-2016 09:19 PM
GMCtrk
05-07-2016 04:32 PM
IARLLC
04-28-2016 11:11 AM
Quick Reply: squeaking when let off brakes
