so..reusing connecting rod bolt and mains..yes or no?
11 Second Hall Moniter
The ongoing debate is, that the ARP hardware increases the clamping force. That additional clamping force is said to "distort" the bearing journal.
When rods are resized, or when mains are align-bored, the caps are torqued in place before the machining. If the machining was done with stock fasteners originally, then ARP hardware is installed later on, your machined journals may no longer be true. This can make some ugly things happen inside your engine.
Hope that made sense, sometimes I have a hard time explaining things.
Mod with training wheels
Here is a good first-hand account of what happens when ARP bolts are swapped in without verifying rod end dimensions:
Rod Bolt Replacement Lesson...if you're thinking about doing it come in.... - LS1TECH
search the forums and report back how many stock rod bolt failures you find. i will keep the OEM rod bolts in place unless it was a fresh engine build. my LS1 held for about 160,000 miles, a couple hundred lbs of nitrous and spinning to 7000 rpm daily and 7500 rpm a few times. when it blew up the rod shattered into 100 pieces but the oem rod bolts were perfectly fine.
