Rear end swapping
Rear end swapping
Not much of a mechanic.
I want to build my rear end up. Been looking at swapping complete. My trucks a 2000 w disc brakes. I want a 10bolt w 4:10 & later pay for a eaton.
What truck should i get a 10bolt w 4:10 to swap right in?
Will i run into driveshaft issues i got a 2 piece steel truck is a ecsb.
In answer to your gear ratio question, it will be printed on the white sticker in your glove box. Assuming you still have the gears the truck originally came with. The ratio will be a gt or gu something i.e. gt5 = 4:10 iirc
Custm2500's Rude Friend
As long as its just a regular 1500 with 6 lugs and not a 1500HD with 8 lugs.
As mentioned RPO Tag is in the Glove Box. These are a few of the more common codes...
GU6 3:42
GT4 3:73
GT5 4:10
G80 Limited slip locking differential
Sounds decent if its in good shape
No. The rear end housing is the same, its the transmission and Transfer case that differ the length of the shaft or 2 piece Vs. 1
GU6 3:42
GT4 3:73
GT5 4:10
