power window conversion
#31
Did you ever get your conversion done?
yesterday i tool it to the dealership to have it flashed. tech said it was not connecting to the doors that I need the DDM and PDM. So i went to junkyard got the use block on the driver side and and passenger side. The doors i got are complete. pretty much hung the doors on and plugged the harness to the side fuse blocks before i even took it up there. It had the door switches plugged in and all. Don's know why they asked for the DDM & PDM if from what i understand the door switches are it. Running the power wire from the fuse box under the hood then where does the other end go? I was hoping this would not be so damn complicated. I wonder if what other mean by the V8 harness maybe having the power wire you speak of?
#32
#34
never saw this
I have been driving my new truck, already has factory 5.3 and power everything the hot rod is just sitting.
#37
I had some success this weekend.
I am going to upload some more photos when I get some better door panels.
I was able to implement 99-02 switches and door panels into my 2003 Silverado. I identified only the necessary wires to run the power windows from the 99-02 door harness which is thick green wire(+from 25 amp circuit breaker) thick black wire (ground) the smaller black wires (grounds also), the light blue and tan wires and obviously the window motor harness dk blue and brown (thicker wires with plug to motor) . I will say I tried and tried but had no success getting the illumination to work I assume the bulbs are burned out in my switches. That is fine with me I will do led upgrade later. I also did not try to figure out how to get the 99-02 door lock switch to work the 2003 door locks.
#38
Bare Bones Power Window Conversion 99-02 or use 99-02 parts.
As stated the most simple way to go. No mirrors lights or locks are covered in this simple swap. I used 99-02 Silverado RCSB door harness from the junk yard. I started by unwrapping the harness and cutting off the wiring that I knew I was not going to use. Mirror,courtesy light,door latch ect. I was left with a bundle of wires, I then referred to a wire diagram, the diagram showed me the thick green wire is the wire that comes from the 25 amp circuit breaker.I hooked all remaining black wires to the main thick ground wire I was not taking any chances.The diagram also showed me the light blue and tan wires(be careful the harness does have another tan wire in it). I got out my trusty jump box and as a test I hooked all the grounds to jump box and the thick green wires to the power side of jump box, I connected the tan wire from the driver side switch to the tan on the passenger switch and did the same for the light blue.I connected my multi meter to the power window motor connector and hit the switch sure enough it read 12 volts, I did the same for the passenger side.I knew it work then so, I ran a 10 gauge power wire from the battery to a 25 amp circuit breaker. I then twisted two 10 gauge(red and black what I had at the house) wires together and two 18 gauge(yellow and blue what I had at the house) wires together, then electrical taped them together like a factory harness, these four wires were later routed under the dash from driver side to passenger side. I added my stripped down power window harness to my existing harness ( I removed my harness from door and did this outside the vehicle it sure makes passing the wire through the door jam boot easier).I then connected the green wire to my added in power(red) wire and the black to my black (ground)wire. I had yellow and blue wire at the house so I connected the tan to to the yellow and the blue to the light blue.So very simple Power=Thick green wire all Black are grounded to thick black wire.Tan and blue connect the switches together. I grounded the wires to the under hood ground on firewall where the hood grounds to. I felt most comfortable with this because grounding to the cab is not reliable. P.S. I didn't take any photos of passenger side( it was getting late) but the procedure is the same.
lucas287
31
01-12-2021 06:18 AM
Corvette454l88
09-01-2016 01:24 AM
Superman09
09-25-2015 05:55 AM
MA$TER_E
09-09-2015 03:14 PM
