power window conversion
Old 12-10-2006, 12:14 AM
LS1Tech Whore
Dirty 30's Avatar
If your truck is a V8 03+ it might work. Mine is a V6 '03 so it didnt work with the V8 interior harness. But since im swaping the engine then it will.
Old 12-13-2006, 04:56 PM
shawn's SS's Avatar
O.K. Now I get it. Your truck had a different harness because it was a V6. Yes, My truck has a 4.8
Old 12-13-2006, 06:13 PM
LS1Tech Whore
Dirty 30's Avatar
Thats right. Im done with the V6 to V8 swap and all the power stuff works now
Old 12-13-2006, 06:36 PM
airtight_python's Avatar
So you guys are telling me the V6 and V8 interior harnesses are different? Or are they part of the engine harness as well? Mines an '02... what do I need to swap in power windows?
Old 12-14-2006, 04:09 PM
LS1Tech Whore
Dirty 30's Avatar
Help!!! The V8 Is In And All The Wiring/computer/bcm. The Engine/starter Turns And Fuel Goes In But The Security Light Is On And Wont Let It Start. What Do I Do???
Old 04-08-2016, 07:52 AM
tpartsman's Avatar
I just did a v8 swap and it had NOTHING to do with interior wire harness.
2003 Silverado 1500 4.3 power lock manual window truck.
This info only applies to (03-06) (99-02 is plug and play from what I can tell.).I have done some junkyard research on factory power window swap, so far I have found out that the interior fuse box is different (inside driver dash) and the bcm will need to be flashed. So far I have acquired, both front door harness,both door panels with switches, power regulators/motors and the fuse box. I was told by a GM tech that everything has to be installed to be flashed because they also program the master window switch. Gm actually calls the switch a ddm (driver door module). I am currently using after market switches and my stock roll up door panels which drives me nuts. I will post more info once I get the flash done.
Old 04-08-2016, 11:39 AM
TrendSetter's Avatar
so then what does it take to do the conversion on a v8 02 ?
Old 04-08-2016, 01:20 PM
tpartsman's Avatar
From what I understand 99-02 door harness,door panels,door switches,window regulators/W-motor(99-06).You may need to run a wire from inner fuse block to battery.You will notice a 20 amp power window fuse on the fuse block yours will not have it.
Old 04-08-2016, 05:26 PM
so there should be plugs under the dash that the door harness plugs into?
Old 06-08-2016, 07:51 AM
Registered User
chacalosa81's Avatar
Hi, new to this forum. actually 1st time being part of a forum. I am trying to install the power windows on to my son's 2003 silverado v8. It was damaged by a tornado around Christmas week. I have installed the complete door from a 2005 silverado extended cab v8. Took it to the dealership and paid 98.00. Then was told that i need it the newer PDM and DDM from a newer truck. So i bought them But after reading up on them think that is not going to make all the power locks, mirrors and windows work. Any help or Advice??
Quick Reply: power window conversion
