PF52 vs. PF47 - PerformanceTrucks.net Forums
PF52 vs. PF47
LinkBack Thread Tools Search this Thread
Old 12-23-2004, 11:17 PM   #1
Default PF52 vs. PF47
Quick question about the oil capacity, The 5.3 takes 6 qts right?? Is taht with the Short filter (PF47) or the long filter (PF 52). The PF52 isnt that much bigger but I'm just curious. THANKS!!
bodyguard6799 is offline   Reply With Quote
Old 12-23-2004, 11:22 PM   #2
Flyer's Avatar
I've always just used 6 guarts and the long filter.
Flyer is offline   Reply With Quote
Old 12-23-2004, 11:23 PM   #3
Truck addict
I've always just used 6 quarts and the short filter.
goshawk23 is offline   Reply With Quote
Old 12-23-2004, 11:31 PM   #4
So nobody checks the level after an oil change?? I know its probably just a small difference , but w/ the oil consumption problems I would make sure its on the full mark at every oil change.
Old 12-24-2004, 12:33 AM   #5
Correct me if I'm wrong, but aren't the PF58 and PF59 our oil filters? Both are the same size, just different threaded hole size?
silent1 is offline   Reply With Quote
Old 12-24-2004, 01:04 AM   #6
Sorry, this will be my first oil change in this truck and the jackass at the parts store sold me the wrong filter. I just checked and AC Delco parts site and its PF47 (short) and PF59 (long duraguard). So now I have to return it.
Old 12-24-2004, 01:21 AM   #7
single digit dreamer
parish8's Avatar
i go short or long, whatever they give me and 6 quarts, i dont even check it anymore after an oil change. it has been exactly 6quarts to fill it up every time.
parish8 is offline   Reply With Quote
Old 12-24-2004, 08:52 AM   #8
I change mine and it is just a little low using 6 Quarts, I add 8 OZ
puts it to the full mark.
900Z1 is offline   Reply With Quote
Old 12-24-2004, 09:49 AM   #9
Flyer's Avatar
Quote:
I will try and find the longer filter though, more filter area .. I can't think of a downside for that one.
Old 12-24-2004, 09:57 AM   #10
I switched at 500 miles from the factory 44 to the 59
The 44 was really small
I am always over 6 qts with the 59
More like 6.25
LS1csherm is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
3.73s or 4.11s? 86 IROC TOWING & OFFROAD PERFORMANCE 5 12-12-2016 04:10 AM
Walbro 450 in a Stock Avalanche Bucket Chavette FUEL SYSTEMS 25 10-28-2015 08:33 PM
Tru Cool Cold Weather Bypass - Do I Need It therock GM Drivetrain & Suspension 4 07-25-2015 10:23 AM
5.3 oil filter pf52? highgmc GM Engine & Exhaust Performance 3 04-18-2003 11:38 PM
Tags
2003, 47, 53, ac, delco, duraguard, pf, pf47, pf52, pf58, pf59, short, size, specifications, thread, vs
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
