molly lube/cam/lifters?
Old 03-29-2012, 12:28 PM
WhiteChevy3's Avatar
Default molly lube/cam/lifters?
Anyone use it on cam swaps and or on the lifters? Read a few posts that it can gum up rollers on lifters.
Or u guys mostly coat em in oil?
Old 03-29-2012, 12:34 PM
TXSZ66AVLANCHE's Avatar
I use moly assembly lube, never had a problem yet on the engines I've built.
Old 03-29-2012, 02:10 PM
nonnieselman's Avatar
Ive always used 80w90 gear oil or whatever i have around.
Its thick enough and hangs around good..
Old 03-29-2012, 06:31 PM
11 Second Club
batboy's Avatar
Just regular engine oil is all you need on the newer generation roller cam swaps.
Old 03-29-2012, 08:13 PM
Ferocity02's Avatar
Engine oil is fine. If you won't be starting it for awhile then assembly lube is ideal.
Old 03-30-2012, 11:35 AM
Ok, thanks guys!!
Midnightrider
12-04-2012 09:03 PM
fastrt
03-09-2011 08:00 AM
Midnightrider
06-01-2010 10:23 PM
Midnightrider
03-15-2010 05:20 PM
OrlandoFL4.8
03-21-2006 03:27 PM
Quick Reply: molly lube/cam/lifters?
