P0304 flashing SES what to check next
Old 08-08-2015, 06:24 AM
rojeho's Avatar
Default P0304 flashing SES what to check next
2001 Suburban 1500 5.3, P0304 drives fine but idles like it has a big cam. SES on and sometimes flashes. I put in a new plug, swapped coil from 4 to 6, and spark plug wire from 4 to 2, cleaned the MAF and cleared the codes.
No change. After a while at idle (like at the end of a traffic light cycle) the SES light flashes until I start to accelerate and then goes out. Scan shows a pending code P0304.
I listened to the fuel injector and it sounds like the other ones on the bank, but I know that won't tell me if it's dirty.
Any thoughts on what to tackle next? I thought swapping all of the spark parts would tell me something. I'm surprised I still get a #4 code.
Old 08-08-2015, 02:40 PM
13 Second Truck Club
trxmxzx's Avatar
Check into knock sensors failing, giving wrong info. Or intake gasket cracked allowing extra air into that area.
My 02 has a similar issue not as extreme. My one knock sensor is corroded- didn't have the money to fix at the time when I did the intake gasket
Old 08-08-2015, 06:57 PM
Custm2500's Rude Friend
1FastBrick's Avatar
Have to swap injector to be sure.
Old 08-08-2015, 07:05 PM
rojeho's Avatar
I changed knock sensors and intake gaskets about 15k ago. That gave knock sensor errors.
Swapped injectors and still not good. P0304 code came back but I've cleared it a few times and it hasn't come back. But coming down to idle at a red light - like at 1 MPH - it gets very surgy-rough and then a lumpy idle. Start rolling at the green and accelerating and it smooths out. No driveability issues. Going to do a compression test tomorrow - any other ideas?
Old 08-08-2015, 07:20 PM
1FastBrick's Avatar
possibly needs a tune adjustment for the idle tables.
legerwn
56
11-15-2015 10:21 PM
03sierraslt
14
10-09-2015 05:53 AM
Cammed4ever
09-30-2015 03:38 PM
Closer_2001
09-24-2015 09:15 PM
Hpinnovate
09-04-2015 02:28 AM
Quick Reply: P0304 flashing SES what to check next
