Need help with fitment 24x10 +25 on a 4/6
Old 02-19-2017, 05:42 PM
Registered User
Blackvmax's Avatar
Default Need help with fitment 24x10 +25 on a 4/6
Im planning on dropping my 06 crew cab vmax 4/6 with a 24x10 +25 and a 295/30 tire. Will this work? Ive already rolled the rear fenders and hammered the inner fender well seam flat. Any advice is appreciated!
Old 02-19-2017, 10:16 PM
La Phantom's Avatar
you will be fine. im running a 6/8 with 24x10s in the back like nothing. I did roll my fenders like you tho
Old 02-19-2017, 10:22 PM
Registered User
Blackvmax's Avatar
Ok cool man thanks! Did you have to do trimming in the front inner also? It looks like the splash guard bracket in the front could get in the way?
Old 02-20-2017, 07:08 PM
La Phantom's Avatar
No I didn't but I am running 22s in the front. If u are runnin 24s all around they may rub a little like on a big bump or something. That's what mine used to do when I had 24s all around but it wasn't at the splash guard bracket it was more on the firewall the upper part of it has like a bump in it for some reason that sticks down about 1 inch and that would rub but my drop is lower than yours so I think you"ll be fine.
The picture on my avatar was with 24s and they were flush and I had rubber band tires on there to help out a little. Yours should sit a little higher than that just don't put a big ol meaty tire on it
Old 02-20-2017, 10:50 PM
Registered User
Blackvmax's Avatar
Ok cool i plan on running 295/30's but may go 285 or 275
Old 02-21-2017, 11:04 AM
Vortec350ss's Avatar
They fit... but they certainly stick out pretty far.
Let's see pics when you have it together.
Old 02-21-2017, 11:07 AM
Registered User
Blackvmax's Avatar
Well i definately may go lower in the future so im trying to figure out if theyll tuck or not with the right tire
Old 02-21-2017, 11:08 AM
Registered User
Blackvmax's Avatar
I cant find anything on anyone running a +25 on a nbs and being low
Old 02-21-2017, 11:11 AM
oh wait... i was thinking -25mm. sorry about that. I was going to say tuckign is absolutely out of the question.
with +25 they will be close... I dont think they will tuck. I would expect them to be very flush with the fenders. It it was a +25 and 9" wide they may tuck.
Old 02-21-2017, 11:12 AM
for reference the SSS wheels are 9" wide with a +22 offset. That esentially means yours wills tick out 1cm further than that. Those wheels are very flush.
