a look at my 2wd rcsb lq4 4l80e 14bolt build
#36
Now that its winter in MA, being unseasonably warm Dec and Jan, I'm finally starting to do some work to the truck. I installed all MSD coils, because my dyno sheets made me believe that I had a bad coil under load. I replaced them all because they have 180k on them, and the MSD coils were on sale. I am now working on installing a 4/6 drop. I just pulled the bed off installed a racetronix fuel pump, so I dont run lean while running nitrous. I was very happy with the fact that the frame is in very good shape. Tomorrow I'm going to install my c-notches and paint the rear frame to protect it from this NE winter salt. Hopefully with in a couple weeks, in my free time, ill get the frame all painted, the lowering kit in, and my new cab mounts in, to eliminate bed bounce.
#39
Got the c-notches all welded in, rear frame painted, and flip kit all installed. We took the gas tank out for the install, then reinstalled it after everything was all painted. Next wed I'll get the front components all put together and the bed bolted back in place.
#40
changed my wheels up so that they are more tucked now. I also finished painting the rear frame and put the bed back on. Here are some progress pictures. I still have to drop the front and adjust my driveshaft loop, because it is now hitting the driveshaft.
