hydroboost swap problems
Old 02-11-2017, 06:35 PM
Wolftrk99's Avatar
Assuming you changed the pedal..
Old 02-11-2017, 06:43 PM
Jake75's Avatar
Yes I changed the pedal. I'm going to bleed the master cylinder again. Maybe there is still air in there. I assume that would cause the pedal to not rebound
Old 02-11-2017, 06:52 PM
Wolftrk99's Avatar
Never seen master cylinder not being properly bled cause what youre describing..worth a shot though, happens with clutch masters all the time...
Old 02-11-2017, 07:01 PM
Jake75's Avatar
i guess if that dont work ill need a new hydroboost unit. Or a rebuild kit
Old 02-11-2017, 10:55 PM
Wolftrk99's Avatar
Before going that far, pull the soring and make sure it isnt binding...
Old 02-11-2017, 11:10 PM
Jake75's Avatar
ok will do
Old 02-14-2017, 04:21 PM
Jake75's Avatar
Ok so I assume when I push the brake and the spring compresses there should be a pushrod to actuate the master cylinder right?? If so then I don't have a pushrod in there. I'm uploading a video now
Old 02-14-2017, 07:40 PM
Jake75's Avatar
Video to support comment above!
Also I wasn't expecting it to pop out lol left it in for a laugh
Old 02-14-2017, 08:00 PM
Wolftrk99's Avatar
Yeah theres supposed to be a pushrod.... that was funny, btw that spring is under a bunch of pressure!!!
Old 02-14-2017, 08:39 PM
Jake75's Avatar
Yea i just found that out haha
I guess ill start looking for that part to replace it. Kinda weird that it doesn't have one
