How many of are running high mileage trucks?
Old 04-07-2015, 12:05 PM
  #151
slick_sierra's Avatar
178k on my 4.8 only had to do knock sensors, intake gaskets, tps sensor plugs and wires.
Old 04-27-2015, 06:40 PM
  #152
Pimpinpete's Avatar
2000 Silverado 4wd 5.3 129k full bolts ons and driven fairly hard. Replaced all kinds of things ie fuel pressure regulator, upper and lower ball joints, tranny, fuel pump, window motors, shocks, tires, grille, plug wires, and everything else I've replaced for go fast parts
Old 04-27-2015, 08:06 PM
  #153
10 Second Club
My "new" to me 2001 Silverado has 246,5XX and counting. Looks mostly original, my guess is that the transmission had to have been rebuilt by how well it shifts.
Old 04-28-2015, 01:58 PM
  #154
weeble1's Avatar
I've got 2 NBS Tahoes in my driveway. One with 225K (still pulls my car trailer all the time) and the other has 298K. Both still bone stock on original motor/trans.
Old 04-28-2015, 02:14 PM
  #155
rudvirus's Avatar
I have a 05 with 236172 miles on it
Old 05-09-2015, 03:47 PM
  #156
Mark Johnson's Avatar
Approaching 100k...............
Old 05-09-2015, 11:17 PM
  #157
SCChevy's Avatar
2003 z71 with 5.3. 158,000 pulling heavy loads all over the south east. Bone stock everything including plugs. Obviously I've replaced tires and brake pads, inner tie rod ends, but that's it. I know that I need to change the transmission fluid and filter (Haven't done it since the first recomended change when it was still covered under the dealership service plan) but I am planning on replacing with a 4l80/higher stall converter so me thinks I'll just let her ride.
Old 05-10-2015, 12:04 PM
  #158
Slowest turbo build ever!
black00chev's Avatar
Yeah don't even bother with the filter. Do a good trans flush and call it good.
Old 05-17-2015, 04:54 PM
  #159
5speedsilverado's Avatar
06 rcsb 4.8 5 speed had 97k
front spindles, front springs, brakes, shocks all around, lots of tires (9 sets), steering shaft, master cylinder and booster
06 ccsb 5.3 4l60e 126k
rack and pinion, water pump, front brakes, both front calipers, tires
Old 05-19-2015, 06:17 PM
  #160
usaf_hess's Avatar
02 Tahoe 4x4
245k+
Water pump, Idler pulley, Knock sensors and harness(intake gaskets while I was there), usual regular maintenance.
Trans is still on its first life but clunking and shuddering under light throttle load and sounds like every lifter is tapping on cold starts haha. Bout to put another trans in but researching 4l80 and 6l80 swaps, it uses a little oil and a smidge of coolant not so often. Just kind of planning right now for heads cam and trans for the future once the wife get something and I use it as a toy/dd.
Its stock.
Quick Reply: How many of are running high mileage trucks?
