Help!! 2000 Silvy 5.3 Power Steering Pump Extra Bolt Hole??
Wrapping up the motor performance mods but I've got 1 question before I press the power steering pulley back on.
There's a threaded bolt hole in the lowest driver side face of the pump that just hangs out in space. I didn't disassemble it so I'm not sure if it should be that way. Can anyone shed some light on this for me?? This is the 2005/2006 hydro-boost pump that came off of a heavy or a Burban....
Also, there's a piece that got blasted clean, painted, has one bolt hole in it. It's definitely a ?shield? of some sort that looks like what I would imagine organizes hose routing or offers protection to hoses??
I've researched this extensively and can't find any diagramming that shows what it is or where it goes...
HELP....
Thanks, V1
HELP....
Thanks, V1
Thanks!
Spoke too soon... I cannot for the life of me figure out the correct location for this tube or the main harness, including Batt + routing thru this piece that's designed I'm sure to consolidate these cables and rout them away from exhaust heat. Can anybody direct me a diagram or picture work that would help?
Thanks!
Thanks!
Can anyone explain in simple terms how and where this wire bracket bolts onto the back, front or engine block? Im stuck.
Can anyone send me a picture of their bracket and how it's mounted? Certainly would appreciate the help!
Thanks!
I don't have a wiring bracket, my wires just run behind the pump. You may be looking at the (missing) right angle bracket that secures the back of the pump to the side of the block.
lxcoupe
07-08-2015 05:49 AM
