Gmt800's easy to steal??!
Just curious if anyone knows exactly how easy these trucks are to steal? I've got a 99scsb that ls for sale and someone tried to steal it! I go to get it in one day to start it and noticed metal shavings in the floorboard. Long story short, somebody popped the door lock from under the drivers side door handle (messed the sheet metal up) and drilled through the bottom of the ignition (where the key goes in). Luckily they got off the center on the ignition and didn't drill in the right spot! I was thinking these trucks had some sort of anti-theft ****, with the key too, but they don't! It took me 1min to find a video on YouTube showing just how easy these trucks are to steal! It can literally be done in 30 seconds! Was everyone else aware of this? Seems like the only real anti-theft precautions is to go
lo-tech! Put a kill switch on, pull some relays, or something else along those lines! I really had no idea these trucks were that easy to steal!
They were drilling to defeat the part that keeps you from turning the tumbler without the key in it. It's hard for a cop to notice that they drilled it in case they get pulled over; a lot less obvious than a busted up column. It's not the only way to force the tumbler to turn which is really not that difficult.
The antitheft is built into the tumbler. There's a resistor that makes contact and is read by the PCM, the resistance must match what it's expecting to see. This is similar in operation to the old VATS system you used to see in the late 80's/early 90's where the "chip" (resistor) was visible right there on the key; for the newer system they just moved the resistor to inside the tumbler so you have a plain key.
It's not a very effective antitheft. It just keeps the really weak amateurs away.
Getting into the truck is as easy as going in under the handle as they did on yours. It sucks because it screws up the door. What they're going for is to push the lock pawl to force an unlock. On both my trucks I deleted the outside door lock tumbler and removed the lock rod. I'm hoping it will keep them from even trying to screw my door up, because even if they do, there's nothing for them to push to make it unlock.
Even so, with some simple break-in tools it's pretty easy to unlock these (and most other vehicles out there, really.) And then there's the good old brick method.
Richard
Richard
Custm2500's Rude Friend
Actually that's the Ghetto way of doing the door.
If you punch the lock through the center of the handle you can twist it with out damaging the sheetmetal on the door. Where the clip goes, the handle will break away real easy.
Jimmy jammers help with that.
Lok-itt column lock is the way to protect the column or at least slow them down... model P250
Really hard to defeat a tow truck though...
[QUOTE=1FastBrick;5390119]Actually that's the Ghetto way of doing the door.
^^^My truck was busted into this way. They took off with my stereo I just finished. Years later the dog locked himself in the truck with the keys in the ignition while I was filling with gas. I asked the station attendant for a screwdriver and a hammer......pretty easy.
My ISS had the lock punched when I bought it, which is what prompted me to go ahead and say F it and delete the outside lock entirely and why I did that to the silver SS I got from you as well. (By the way that whole thing with moving the tab in the sheetmetal for the keyless Escalade handle, as I'm sure you probably figured out, was because that handle ended up being for a rear door. Either way no biggie since the ISS door needed repair in that area already.)
Richard
