99 Tahoe hydroboost install
Hydroboost installed on a 2 door tahoe. The whipple and intercooler will be back on in a couple of weeks.
No leaks! Yay. After doing all of the bleeding procedures I started it up and the engine wanted to die. Doh! I forgot to plug the hose that went to the vac booster (capped it off on the intake manifold). Started it up again and all went smoothly. I haven't installed my cooler yet because I need to figure out where to put it but it will be installed soon.
Parts:
- Hydroboost and Master cylinder from local junk yard (98 HD truck)
- New AC Delco steering pump for a hydroboost truck
- Ebay Mounting plate with centered whole
- Hydratech aeroquip hose and fitting kit for my application
- Various stainless nuts and bolts from mcmaster
- 3/8-16 thread die for the hydroboost pushrod
- Ac delco brake light switch
- Steering and brake fluid
I took the snap ring off the unit and unscrewed the retaining nut with a big adjustable wrench and test fitted the new plate. All fit perfectly and the holes of the new plate matched the stock plate holes.
I bought the plate from ebay from the seller sterlingworth16. It is 3/16" thick steel.
http://motors.shop.ebay.com/merchant...rmrsZ1QQ_fromZ
Pic of the master cylinder.
I cut and threaded (3/8-16) the pushrod making it shorter by +- 5 mm. Once I get my vacumm booster off I'll measure and adjust the rod to the same length. The joining nut is stainless and 1-1/8" long. By doing this and using the center mounting plate, I can reuse my stock brake pedal.
End result:
Hydratech hose and fitting kit for a 99 tahoe. These are Aeroquip TFE high pressure hose and fittings. Great service and packaging on hydratech's part.
Before
After
Filthy!
Still need to tidy up some odds and ends and bleed the brakes.
Parts:
End result:
Before
After
Filthy!
SLOPONY
20
10-18-2016 06:05 AM
InsaneDomestics
07-27-2015 02:42 PM
mrgrim
07-08-2015 08:12 AM
