flashing check engine light but no codes
2004 Silverado with 4.8L engine..... 82,000 miles..... hit the highway for a 150 mile ride, and the check engine light started to flash. it will flash anywhere between 3 and 45 times..... it flashes, then goes away for a few miles, then flashes again, etc... the whole way. it never stays on steady. in town driving, it never comes on..... got home and it was idling rough....started it the next morning and it ran great and idled smooth.....took it to the shop and had the codes read there were none......new plugs and wires....and it did it again yesterday, but still no codes...... any ideas???
Failing coil pack(s)? Like FFDP said, you'd want to log it while it is happening. Does it come on when you are going up an incline or attempting to accelerate? I'm not sure why it wouldn't log a code. I've seen the misfire code come up stored in the computer before, but didn't remember seeing anything wrong at the time. If you can log it and find the specific cylinder, you can try swapping the coil to another cylinder.
Good luck.
Good luck.
Custm2500's Rude Friend
Not sure about the shop you are taking it to but they should be able to read the codes stored in the history.
Any decent scanner should be able to read current codes as well as codes stored in the history.
Some of little hand held code readers (Especially old ones) may not be capable of reading codes stored in the history.
If the mechanic You used is not smart enough to check the History codes or is not using a scanner that is capable of checking the history, you should be looking elsewhere for a real mechanic.
With that being said,
If you can get the stored history codes, that can point you in the right direction.
Check Fuel pressure at Idle and Under Load. I have seen failing pumps dip under load.
With that being said, there isn't a whole lot else you can check without a scan tool.
You need to be able to monitor misfires current and history, sensor readings like the O2 sensors, RPM, and so on.
