can't remove relay from fuse box - PerformanceTrucks.net Forums
Thread Tools Search this Thread
Old 03-14-2005, 06:45 PM   #1
Default can't remove relay from fuse box
the last 2 times i have changed my fuel filter, i tried pulling the fuel pump relay in the fuse box. but for some reason i can't pull it loose. what am i doing wrong?
KeukaZ71 is offline   Reply With Quote
Old 03-14-2005, 06:48 PM   #2
Why are you doing that? Seems like an extra step. I just release the pressure from the valve on the fuel rail. Not that much gas comes out and it doesn't hurt anything.
Soquel is offline   Reply With Quote
Old 03-14-2005, 06:53 PM   #3
Quote:
thanks
i saw that option too in my haynes manual, but i also read on this forum you could pull the relay as well.
i still would like to know how to get the relays out
Old 03-14-2005, 07:37 PM   #4
SnakeOiler's Avatar
You have to pull REALLY hard. Those relays are little buggers to get out. Wiggle it a little while pulling on it. . . . I think I'm starting to get into the offensive
SnakeOiler is offline   Reply With Quote
Old 03-14-2005, 08:30 PM   #5
Onyx 02's Avatar
Quote:
What he said will do it. I used a pair of pliers to get mine out.
Onyx 02 is offline   Reply With Quote
Old 03-14-2005, 08:38 PM   #6
thanks. not sure why it is such a bitch to get out. i pulled pretty hard. i'll try to get a better grip next time
Thread Thread Starter Forum Replies Last Post
2010 ly6 6.0 chvy=power GM Parts Classifieds 3 09-08-2015 11:06 AM
f/s Matco 56 inch 4s tool box LT-1 SS Texas 0 09-03-2015 07:31 AM
Electrical Issues Idryfly5 GMT 900 Trucks General Discussion 1 09-02-2015 12:06 AM
2 pioneer 12's in a under the seat truck box jtphelps289 Miscellaneous Classifieds 0 09-01-2015 09:11 PM
Amber vs bright white lights - Off Road silver-mod-o THE TRUCK STOP 9 07-27-2015 05:24 PM
Tags
2001, block, box, fuse, fusebox, gm, hard, pull, relay, relays, removal, remove, removing, silverado, tool
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
