Broken Window Cable - PerformanceTrucks.net Forums
Broken Window Cable
LinkBack Thread Tools Search this Thread
Old 10-07-2006, 04:22 PM   #1
Default Broken Window Cable
I have a broken driver door window cable in my 02 silverado.
Can you replace just the cable, or do it come as a unit cables and motor?
Are there instructions to do this anywhere?
Thanks, John.
JOHN LAWSON is offline   Reply With Quote
Old 10-07-2006, 07:50 PM   #2
9 Second Truck Club
tarinitup's Avatar
it comes as a complete assembly with motor. Try searching window regulator and they are about 100 buck shipped online. It a not very hard to replace if you have a little mechanical knowlege.
tarinitup is offline   Reply With Quote
Old 10-08-2006, 01:08 AM   #3
unfortunately they come as a whole i had to replace my pass side (go figure lol)
i spent just under 100 at the parts store to do it
negativeswitches is offline   Reply With Quote
Old 10-09-2006, 10:57 PM   #4
PT's Slowest Truck
budhayes3's Avatar
...I saw one for sale on ebay the other day...
budhayes3 is offline   Reply With Quote
Old 10-10-2006, 11:47 PM   #5
Quote:
I suppose you can buy the whole assembly if you want to but that's not necessary. Then again if you can get a GM regulator and motor for less than $100, that's not a bad deal.
The cable in my truck's driver's side door broke a year ago and I replaced the regulator only. Here's the GM bulletin which addresses this;
Body - Window Regulator Replacement
Bulletin No.: 05-08-64-029B
Date: February 16, 2006
INFORMATION
Subject:
Power Window Regulator Now Available Separately From Motor
Models:
2002-2006 Cadillac Escalade, Escalade EXT
2003-2006 Cadillac Escalade ESV
2000-2006 Chevrolet Silverado, Suburban, Tahoe
2002-2006 Chevrolet Avalanche
2000-2006 GMC Sierra, Yukon Denali, Yukon XL
Supercede:
This bulletin is being revised to add the service procedure. Please discard Corporate Bulletin Number 05-08-64-029A (Section 08 - Body and Accessories). This bulletin is being issued to inform technicians that when performing a repair to the power window system, it is no longer necessary to replace the complete window regulator assembly. GMSPO has released the power window regulator for the left and right front doors separately from the motor.
I hope this helps.
Nick
ngianop is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Ported and milled 317s, milled 862s, engine covers gmcyukon GM Parts Classifieds 6 10-04-2015 12:03 AM
PRC Beehive Spring Failure 5.3 Velocity1 INTERNAL ENGINE MODIFICATIONS 7 10-02-2015 09:01 AM
swapping alum block for iron trevorh1 INTERNAL ENGINE MODIFICATIONS 4 09-27-2015 09:47 PM
Sleeper 535 - Twin Turbo with Tune, $60,200 MSRP, executive express for pennies..TX Closer_2001 Cars and Motorcycle Classifieds 2 09-24-2015 10:15 PM
Tags
02, 2002, broken, cable, denali, door, drivers, escalade, gmc, power, replacing, sierra, suburban, window, yukon
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
