Broken Head Bolts inside block...help
Old 02-17-2011, 03:19 PM
  #21
Wearin' da big hat
00ChevyScott's Avatar
Originally Posted by dewey04
Take the broken bolts back to O'reilly's with your receipt and raise hell. Tell them you want ARP's or your going to start a picket line in front of the store.
If you did that at my store, I'd tell you to stop being a cheapskate and buy the ARP bolts to begin with
Old 02-17-2011, 03:20 PM
  #22
Bumpers's Avatar
good deal man... glad you got em out now get it ready to come to jackson
Old 02-17-2011, 03:47 PM
  #23
Turbo Silverado's Avatar
Next time try adding ARP molybdenum grease before putting the bolts back on.
http://shop.edoperformance.com/tomei...e-p-10085.html
Old 02-17-2011, 05:24 PM
  #24
Bama2door's Avatar
Thanks guys, made some good progress today. Cleaned all cylinder walls up real good, put in new tr224 cam and bolted everythin back up for that. Also got one head put on and torqued with NEW bolts and put the rockers and pushrods back in so that side is all done. Just have to put the other head on tomorrow and change out the rear main seal, then shes ready to go in Saturday.
I tried ordering ARP bolts from Summit yesterday online and got a call from them saying my card didn't go through. I went to CVS and purchased a gift card to put money on so I could order them online but it didn't work (which is bullshit) so I just got some new TTY from oreillys...maybe next time haha.
Old 01-14-2017, 06:35 AM
  #25
midnightbluS10's Avatar
I know this is old, but this is incorrect and should be corrected.
GM recommends no lube or threadlocker on the threads of the TTY bolts. They should be clean and dry. There is a recommended procedure for conditioning the block threads prior to installation of new bolts, as well.
Old 01-14-2017, 11:17 PM
  #26
2002_Z28_Six_Speed's Avatar
TTY sequence is designed to bring the bolt *into* the plastic region. Installing twice based on the factory sequence is a hell of a stretch. No pun intended. If you use a TTY twice you would have to do to it based on a different install sequence and probably a very low power operation. Rock Auto has factory bolts on the cheap. No reason to reuse. If you use lubricant reduce torques 10%. But better to follow factory specs to the letter.
Nothing is better than TTY. Perfect amount of clamping effort everytime!
Old 01-15-2017, 11:15 AM
  #27
MikeGyver's Avatar
TTY sequence is designed to bring the bolt into the plastic region
zblee
63
06-10-2023 01:25 PM
slowlsx
08-10-2015 05:33 PM
Denali08
08-09-2015 04:34 PM
signguy62
07-27-2015 03:42 PM
4B11T
07-13-2015 03:48 PM
Quick Reply: Broken Head Bolts inside block...help
