Aftermarket Cooling Options?
Old 09-02-2014, 12:05 AM
Velocity1's Avatar
Thumbs up Aftermarket Cooling Options?
Has anyone got first hand knowledge/experience with aftermarket alternative Efan cooling systems too the GM system?
I've got the OEM clutch fan and getting ready to tear it all apart to do cam and head upgrades. Thought it would be a good time to upgrade the cooling fan system at the same time.
Truck is a 2000 Z71 Silverado 1500HD 4x4, Circle D 3000 converter, new 34" core rad, 40k gvw trans cooler, a/c condenser. I'll be adding the SLP 180* t-stat but would like to have the better more efficient cooling of the Efans if they're available.
Old 09-02-2014, 12:23 AM
oakley6575's Avatar
I've had aftermarket fans in my truck. After them I replaced with the stock 05+ electric fans. By far the best fans I've used or seen for our trucks. I bought the fans and all the wiring/fuse panel for $75 at a junk yard I believe. I'd highly recommend them over anything aftermarket.
Old 09-02-2014, 01:44 AM
Velocity1's Avatar
Seems like the GM retro Efans are difficult to locate here in MD. Often frontal collision took them out or they've already been picked. When I do locate a system almost always something is missing. When they're available prices here are very high and that's removing them yourself of course. Then there's no guarantee.
Old 09-02-2014, 09:55 AM
Mark Johnson's Avatar
ebay...........
Old 09-03-2014, 11:05 AM
Slowest turbo build ever!
black00chev's Avatar
The easiest thing to do for our 2000s is to get a set of efans from an LS1 and then buy the harness available online. Its plug and play aside from splicing into one wire.
Old 09-03-2014, 12:24 PM
Mod with training wheels
smokeshow's Avatar
Originally Posted by 2001 Sierra
ebay...........
Yeah I've bought new fans on ebay for cheaper than used ones from a junkyard.
Old 09-03-2014, 12:29 PM
gamble686's Avatar
Cheapest and best fan setup I have found is using mid 1990s ford windstar minivan Efans. There are 1000s of minivans sitting in junkyards and they are usually like $40.
Old 09-03-2014, 10:56 PM
SnakeOiler's Avatar
You can't go wrong with '05 factory fans. Find some.
Old 09-04-2014, 11:18 PM
Only thing about the 05 fans is on a '00 you need to upgrade to the larger radiator too.
Old 09-05-2014, 08:42 AM
Velocity1's Avatar
Thru the grill I've measured the core right at 34". Replaced the rad a year ago with factory rad from GM. I'm determined to find a set of the '05 fans. Once the head and cam work is done I'll install the electric fans rather than a new clutch fan setup.
Lthompson
10-02-2015 12:45 AM
carid
10-01-2015 09:22 AM
Wrecker 426
09-30-2015 09:39 PM
murderedSS
09-27-2015 10:16 PM
Quick Reply: Aftermarket Cooling Options?
