still acting up under part throttle when not warmed up
Old 07-26-2007, 02:12 PM
regency's Avatar
Default still acting up under part throttle when not warmed up
when the truck is not warmed up, it will spit and sputter and jerk you all around. i cleaned the o2s with a torch "allen nelson told me to along with members on here" and it acted right for about 20 mins then started doing this all again. i have a code but need to have it read.
Old 07-29-2007, 10:13 PM
regency's Avatar
i swapped out my O2's with the rears that i had deleted and man i acted ALOT worse
Old 07-30-2007, 12:07 PM
FastCrewCab4x4's Avatar
I Think it's only while your in open loop that your having a problem, Mine does the same thing till it gets warmed up. I can give it gas in neutral and it'll sputter while accelerating, but once warmed up it's just fine
Old 07-30-2007, 12:09 PM
TouchOfEvil04's Avatar
Mine stutters a bit as well while she's cold. But after a good 2-3miles all is well.
Or i just remote start it about 5 mins before i walk out the door and she is fine.
Old 07-31-2007, 12:50 AM
CashDudeHomie's Avatar
I recommend NGK brand sensors. Mine was doing the same thing (spudder would go away when throttle was pressed about 75%, but would throw me back in the seat!) and when I went to the NGK's it hasn't done it since. Seems to be a sideeffect of no cats and/or longtube headers from what I can tell. The stock front O2's just crap out after a while, probably because they don't heat up as fast without the cats. The vette O2's are supposed to be better as well, but I haven't tried them.
Old 07-31-2007, 06:12 AM
Import Moderator
beastmode's Avatar
mine also acts up a good bit when i first cold start, if i come to a complete stop for to long ill stall frequently
Old 07-31-2007, 07:01 AM
My truck didn't act up any until i cammed it. Had longtubes for almost a year and it never acted funny.
Old 07-31-2007, 11:27 AM
regency's Avatar
im thinking that its all comming from the overlap of the cam and clogging up the O2's. yes its only doing it in open loop because my O2's were not going into closed loop when allen nelson went for a ride with me.
mr03silverado
06-26-2016 06:05 AM
TimDave217
08-24-2015 04:38 PM
Ferocity02
08-07-2015 08:50 PM
V-seriesTech
07-28-2015 12:31 PM
ferrellrooster
07-13-2015 09:53 AM
Quick Reply: still acting up under part throttle when not warmed up
