6.0 swap help needed..The truth..?
ok guys, someone has to know for sure, the 100% truth on this.. Heres the deal, i have a 1999 silverado extended cab shortbed 4x4 with the 4.8 engine and 4l60e trans, all original. I want to swap in a 6.0 and keep my 4l60e and stock torque convertor and all, will beef up the trans to hold up to the 6.0.
Ok, From what i have heard, in order to use my stock convertor and 4l60e, i need to find a 2001-up 6.0 to avoid the oddball longer crankshaft. ok, that would be no problem, but i read somewhere yesterday it needed to be a 2004-up to avoid the oddball longer crank, so back to the drawing board.. Does anyone know the truth? I know an LQ9 would bolt right up seeing as they were mated to 4l65e and 4l70e, but most likely it would be an lq4 that was mated to a 4l80e that i would use being as they are cheaper, but, will the lq4 work, even if it is newer than 2001 or will it STILL have the longer crank? I am looking at a 2004 lq4 out of a savanna van and another 2003 lq4 from a 2500 truck, will they work or will they have the dreaded longer crank? I dont wanna mess with having a custom convertor made or any of that, i just want to pull out the 4.8 and install the 6.0 and be done.. anyone know the truth? If all year lq4's will be a problem with the longer crank, i guess ill have to save longer for the lq9, need to know the truth before i buy anything..This is already being done on a tight budget and i sure dont want to order an engine and it not work without custom convertors and all.
Thanks
Thanks
I am pretty sure you are correct in that only the 99-00 had the spacer built on the crank... if you get a later one then it will have the removable spacer and a "flat flywheel" used for 4l80e's. So just reuse your 5.3 "concaved" flywheel on your 6.0 without the spacer and you will be good to go.
ok, so for sure i am safe with a 2001-06, even if it is an lq4 that came with a 4l80e originally, it will have a removeable spacer on it, no exceptions? Just wanna be sure because i dont want to order one and it arrive and have the longer crank and then i cant use it. Like i said, it wouldnt be a worry if i get a lq9, but it will probably be an lq4 from a 2500 truck or van..
again, so for sure 2001-06 wont have a longer crank, just the removeable spacer?
Thanks!
Thanks!
ok, so for sure i am safe with a 2001-06, even if it is an lq4 that came with a 4l80e originally, it will have a removeable spacer on it, no exceptions? Just wanna be sure because i dont want to order one and it arrive and have the longer crank and then i cant use iflywheelsaid, it wouldnt be a wflywheel if i get a lq9, but it will probably be an lq4 from a 2500 truck or van..
Thanks!
Thanks!
awesome, thanks! Only other question now is, i have also heard that 1999-2000 4.8's also had the oddball longer crank, if this is true, im screwed because mine is a 1999 with the 4.8...
Custm2500's Rude Friend
You have nothing to worry about.
The Longer crank 4.8's were only used on the manual transmission and the 4L80E in 99-00. They were NOT used with the 4L60E.
The 6.0L from 99-00 had Iron heads and the long crankshaft.
An LQ4 from 01-07 Classic body style or LQ9 from 02-07 Classic Body style will swap right in.
As mentioned, the LQ4 will need the spacer removed and to use the old fly wheel from your 4.8L.
