4.8 oil leak - PerformanceTrucks.net Forums
4.8 oil leak
LinkBack Thread Tools Search this Thread
Old 07-08-2009, 02:20 PM   #1
Default 4.8 oil leak
So i recently bought a 2001 silverado RCSB 2 wheel drive with the 4.8. While changing my oil I noticed that it has apparantly been leaking oil around the oil fill area on the passanger side head. I didnt know if there is a gasket here or if anyone else has experienced this? The oil gauge reads 60 while cruising but will go up to 80 under full throttle. What does this mean?
thanks
wahoo09goalie is offline   Reply With Quote
Old 07-08-2009, 02:24 PM   #2
Wearin' da big hat
00ChevyScott's Avatar
The oil gauge is normal and someone probably spilled oil when they were filling it. If it isn't that, then the valve cover gasket might be bad, but there really isnt all that much oil up there
00ChevyScott is offline   Reply With Quote
Old 07-08-2009, 03:01 PM   #3
LsxCody's Avatar
^ that would be my guess
LsxCody is offline   Reply With Quote
Old 07-08-2009, 06:01 PM   #4
PT's Slowest Truck
budhayes3's Avatar
Yea, the oil fill tube usually has an oily residue on it from either spillage or slight seepage from where it goes in the valve cover. I don't think that there's any gasket there, just a plastic tube that twists and snaps in. If it's not pouring out I wouldn't worry about it...nothing a can of brakleen can't fix lol, or as we call it at work, "gasket in a can"...
Your oil pressure's normal, keep on truckin'
budhayes3 is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Cleaned MAF, ping went away...for a day lucas287 Tuning, Diagnostics, Electronics, and Wiring 12 09-10-2015 10:31 PM
About to burn the truck down creekrat Tuning, Diagnostics, Electronics, and Wiring 2 09-10-2015 01:59 AM
Any simple answers? custm2500 Tuning, Diagnostics, Electronics, and Wiring 7 09-08-2015 06:53 PM
Do all the 72000 Air Lift kits come on a few times while driving? mr03silverado GM Drivetrain & Suspension 0 09-03-2015 12:43 AM
4.8 tvs1900 boost and pully ?s hackrst FORCED INDUCTION 16 09-02-2015 06:27 PM
Tags
01, 1999, 2000, 2006, 48, chevy, fill, filler, leak, leaking, leaks, oil, rear, silverado, tube
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
