4.3 to 5.3 Swap Fuel System Confusion
I bought an '05 2WD 4.3 extended cab with a knocking engine. Then I got a smashed '03 5.3 4x4 as a donor vehicle. Sounded easy enough...
I didn't realize that the fuel systems had changed until I pulled out the 4.3 yesterday. I already licensed the donor trucks PCM with HPTuners and deleted VATS before I pulled the engine.
My plan is to use the '03 PCM in the '05. Should I swap the '03 (return) fuel system over to the '05 (returnless)?
Any info is greatly appreciated. I've been reading a lot about it and I'm still not 100% sure which way I should go.
I went return style in my swap truck. Truck was an 01 and the donor tahoe was an 01. I also changed over to an in line pump, and rear mounted fuel cell. I personally like return style. I just feel like I am avoiding any dead head fuel issues.
