03 Chevy Dash Cluster Problems
Old 01-20-2008, 12:36 AM
RKRJ11's Avatar
Question 03 Chevy Dash Cluster Problems
Hey Guys,
I know this my be an old discussion question, but I need some help. I have an 03 Silverado, got in it to go somewhere and looked down after driving about a mile and nothing on my dash worked. I mean no speedo,no tach, no fuel guage, no oil oil gauge, no nothing, every needle is sitting to the left as if the ignition is off. All of my dash lights are working and the truck is running fine. Any info will be help. Thanks in advance. Oh, and anyone know a ballpark figure to fix this.
Old 01-20-2008, 03:51 AM
Where's the Beef?
viciousknid's Avatar
sounds like a fuse.
Old 01-20-2008, 09:27 PM
TX Tahoe Z71's Avatar
GM is mailing out warranty letters about the 03 gauge clusters. They have been having all kinds of issues with them. Call GM and see if you are covered; it's a 7 year/70,000 mile warranty. Hope it works out for you.
Old 01-21-2008, 03:01 AM
Where's the Beef?
That problem was supposedly just a Speedo and Fuel gauge problem, but it Could be the same thing.
Old 01-21-2008, 11:08 AM
Sounds like the cluster to me!
Old 01-28-2008, 04:00 PM
Speedextreme's Avatar
Have someone check your ignition switch! The one in the column. I had the same problem to where I would drive down the road and all of the sudden the gauges would all go to zero (off position) then just come back on like I had just turned the key on again. Then be fine for 2 miles and do it again!!! It started out simple, only happen once in a 25 mile drive, then when I finally found this out it was up to once every 3 miles or so the gauges would do it.
Drove me nuts till a local shop had the info on it and got it fixed for me. Like I said it ended up being the "electrical" ignition switch in the column, not the "tumbler" or "keyed" ignition. But the electronics between the keys and wire loom. I think the total job cost me $120.00 if memory serves me correct. There was an "Informational write up" on this but Chevy didn't want to make it a recall!!!
Laters
Old 01-30-2008, 08:32 AM
2k4tahoe's Avatar
take it to a dealership and tell them your cluster is out. i just took my tahoe in last week they got my info (mileage..etc) and the part already has come in to replace it. 70K miles is the limit
kalikid06
20
10-13-2015 07:37 AM
silver-mod-o
09-07-2015 10:22 PM
mayko
09-07-2015 12:24 PM
the owl
09-04-2015 04:09 PM
montecarloss
09-02-2015 04:44 PM
Quick Reply: 03 Chevy Dash Cluster Problems
