03+ bcm/interior swap into 99 truck?
Old 10-15-2016, 04:03 PM
Restricted
JordanH's Avatar
Default 03+ bcm/interior swap into 99 truck?
Pulled everything out of a 04 Silverado. Completely everything, steering colum/wheel, dash, interior, through firewall harness, door harnesses, mirror/headliner harness, everything. Has anyone done a swap into the 99-02 style trucks?
Old 10-15-2016, 04:29 PM
Custm2500's Rude Friend
1FastBrick's Avatar
Hope you got the door harness and the interior door panels with switches and seats too!
Old 10-15-2016, 07:33 PM
Restricted
JordanH's Avatar
I did, I litterally got everything!
Old 10-16-2016, 06:31 AM
About20ninj45's Avatar
What about the pcm and ecu?
Old 10-16-2016, 09:51 AM
Restricted
JordanH's Avatar
No, I figured they were the same? Or at the least, the 99 could. E flashed with a 03+ Os
Old 10-16-2016, 06:27 PM
1FastBrick's Avatar
Nope! Need the ECU and BCM from the 03- up trucks along with airbag module and possibly the front sensors. You will need a cluster too as those are different. Also the XM stuff if your going to use that as well.
99-02 is completely separate/different from 03-07 classic. Even some of the stuff from 03-04 to 05 is different and same thing with 06-07 classic stuff.
Old 10-16-2016, 07:56 PM
Restricted
JordanH's Avatar
I got the under hood distribution block and everything from there into the cab, gauge cluster, everything. Turns out the under hood distribution block on the 03+, is also diffrent from the 99-02, so I'm going to get a more in depth look at all this tomorrow.... but the whole thing might be a bust! I'm pretty sure I don't wanna swap out the engine harness, plus this 99 is a dbc, not sure how this will affect anything but I'm pretty sure I don't feel like dealing with it! At the very least, the power seats will be hooked up and possibly the newer style door panel switches... I don't see those being a big deal
Old 10-30-2016, 07:40 PM
vipergtrdj's Avatar
Not trying to hijack the thread, just had a question regarding the swap. If you have the BCM from the 03 and an ecu from 00 lq4, would it work or no? You'd need the 03 ecu and the dbw setup ?
chesterperformance
09-23-2016 08:36 PM
2KRedSilverado
08-17-2016 05:59 PM
Supajut
08-16-2016 07:02 PM
Hillbilly Silverado
08-13-2016 06:33 AM
greenturtle05
20
08-04-2016 09:12 AM
Quick Reply: 03+ bcm/interior swap into 99 truck?
