Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
Go Back   PerformanceTrucks.net Forums > GENERAL MOTORS SPECIFIC FORUMS > GM General Discussion
Sign in using an external account
Register Forgot Password?
Register Albums FAQ Members Calendar Search Today's Posts Mark Forums Read VendorsGarageUsed CarsStore TSBs & Recalls
Welcome to PerformanceTrucks.net Forums
LinkBack Thread Tools Search this Thread
Old 11-14-2010, 06:34 PM   #1
Trader Rating: 1
Default NEED HELP MAJOR PROBLEM my truck won't go over 40 MPH need to fix TONIGHT!
My 2007 silverado 5.3 auto truck crew cab is having a issue. Going down the highway all of a sudden all my warning lights came on. Traction contol, stab. etc. I know can't drive over 40 mph. It says conserving power mode and is shifting hard. It is a work truck and needs fixed before the morning It is thousands of miles from home. HELP
__________________
1992 Z28 L98,700r4,vortec heads,SD intake,SLP ported runners,ported plenum,SFC, ebaich pro-kit,KYB adjust. shocks, rolled rear fenders, blah etc tpi motor build in progress
2005 sierra, headers, no cats, cai, bolt ons...DD
2011 crew sierra sle-work truck
2011 crew silverado z71, ranchhand bumper-work truck
david068513 is offline   Reply With Quote
Old 11-14-2010, 06:50 PM   #2
Trader Rating: 0
Mrgoodwrench3's Avatar
For some reason it has gone into limp mode. Could be several things. Try disconnecting the battery for 15 minutes. Try it again.
__________________
2010 Camaro 2SS, Kooks Long Tubes, Kooks Exhaust, Snow Methanol Injection, PFADT Suspension
Mrgoodwrench3 is offline   Reply With Quote
Old 11-14-2010, 07:11 PM   #3
Trader Rating: 1
Ok, what if that doesn't fix it?
__________________
Old 11-14-2010, 07:22 PM   #4
Trader Rating: 0
Need to read the codes then proceed with diagnosis.
__________________
Old 11-14-2010, 07:40 PM   #5
Trader Rating: 7
Where's the Beef?
viciousknid's Avatar
Send a message via MSN to viciousknid Send a message via Yahoo to viciousknid
Usually it will get out of limp mode if you just shut it off for a few minutes. Could be a number of things. ABS sensor or TP sensor for start. Really need to find a local auto store that will scan it for ya and go from there.
__________________
-Joshua
'03 408 ECSB|244/248 612/615 112|LT ORY XR1|FLT4|COS3 SD EFI Live|Circle D 3000 stall|4.30's|truetrac
To Err is Human. To ARRR is Pirate.
viciousknid is offline   Reply With Quote
Old 11-14-2010, 08:12 PM   #6
Trader Rating: 1
If I reset it does it store till I get to a scanner?
__________________
Old 11-14-2010, 08:18 PM   #7
Trader Rating: 7
Where's the Beef?
If you undo the battery you will clear the codes. Did it not go back to normal after having the key off for a few minutes?
__________________
-Joshua
Old 11-14-2010, 09:04 PM   #8
Trader Rating: 5
sixltrbtr's Avatar
Send a message via Skype™ to sixltrbtr
May not be it but check all the wires at the throttle body. These trucks have an issue with the wires breaking inside the insulation. Tug on each individual wire near the plug at the throttle body. If one is bad you should be able to pull the wire in half pretty easily. Then all you need to do is splice the wire back together if it's not too close to the connector. If it is you'll have to get a new connector from the dealer and splice them all.
__________________
2003 Silverado RCSB. Magnacharged LQ9 PB 11.51 @ 119.65 mph DD
sixltrbtr is offline   Reply With Quote
Old 11-14-2010, 09:49 PM   #9
Trader Rating: 0
bow tie guy's Avatar
battery age......................
battery voltage is............
serpentine belt is .................
these side post batteries are crap mine showed good
but internally the terminals were bad
bow tie guy is offline   Reply With Quote
Old 11-14-2010, 11:31 PM   #10
Trader Rating: 1
It has a stock battery, 350k miles on the truck. Amps are fine.
__________________
PerformanceTrucks
Ford F150
Paid Advertisement
Tags
15, 2007, 30, 35, 40, chevy, exhaust, mph, ower, past, performance, problems, silverado, truck, wont
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
PerformanceTrucks.net and InternetBrands, Inc. are not affiliated with the Ford Motor Company
