Electric Fans - Pin 33
Old 04-08-2009, 02:08 AM
  #31
Truck Sponsor
Wheatley's Avatar
it does now
Originally Posted by BlackGMC
I am pretty sure the 03 and 04 are the same. I did it on my 04....
Here is the thread.
https://www.performancetrucks.net/fo...ighlight=efans
Hopefully your using EFI Live, cause HPtuners does not have the AC pressure adjust needed to control the second fan correctly....
http://www.hptuners.com/forum/showthread.php?t=8858
Old 04-08-2009, 11:46 AM
  #32
midnight_bowtie's Avatar
Originally Posted by CashDudeHomie
Nonnie, how do you do it on a 99-02? I have the 03+ diagram, but I can't really read it. I have had some 05 fans for like a month just sitting at my brother's house because I have no idea how to hook them up. I want to use both PCM pins because I have the new HPTuners beta version. Please help!
One of my impala fans gave out and I want to step it up to the 34" rad w/ the bigger efans. Would really like to do this right this time around.
Old 04-08-2009, 02:20 PM
  #33
SilverDog's Avatar
Here are some diagrams I have.
#1 similiar to Nelson Harness
#2 similiar to 05+ Gm Harness
#3 05+ Gm Harness
#4 05+ Gm Harness, I Modified for 2 fuses
The first one uses the ac as a trigger while the other three use the two pin setup. Not sure who uses #2.
Old 04-08-2009, 03:11 PM
  #34
nonnieselman's Avatar
Do yall just need the harness info???
I used this diagram.
run the wire thats suppose to go to the AC ground to the PCM pin 33 and activate it in the tune and Vola..
Old 04-08-2009, 03:24 PM
  #35
Thanks man. installing the 34"rad and fans shouldn't be too much of a hassle if at all but wasn't sure how to get them running. I didn't want to use the same wiring as now and have them running constantly. Did you make your own harness or mod one?
Old 04-08-2009, 04:27 PM
  #36
CashDudeHomie's Avatar
We're still trying to figure out if you can use pin 33 on a 99-02 truck...
Old 04-08-2009, 04:35 PM
  #37
I made my own..
you can use Pin 33 and 42....
on EFI Live you go to System > A/C > Parameters
{G0106} A/C Auto Recirculatoin - Fan #2 Control
Then go to System > Fans> Parameters
{G1203} Type of Fans Fitted To vechicle - Series Parallel Fans
This is how the stock Fbody tune is setup..
here is my Fan settings BTW
I know HPT is different, but you get the idea?
Old 04-08-2009, 04:36 PM
  #38
Old 04-08-2009, 04:39 PM
  #39
KySilverado's Avatar
I think the point is that you posted a wiring harness diagram that won't work using pin 33.
Old 04-08-2009, 04:42 PM
  #40
This one works..
It grounds the relays.
Quick Reply: Electric Fans - Pin 33
