Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
Go Back   PerformanceTrucks.net Forums > GENERAL MOTORS SPECIFIC FORUMS > GM General Discussion
Sign in using an external account
Register Forgot Password?
Register Albums FAQ Members Calendar Search Today's Posts Mark Forums Read VendorsGarageUsed CarsStore TSBs & Recalls
Welcome to PerformanceTrucks.net Forums
LinkBack Thread Tools Search this Thread
Old 07-08-2009, 01:20 PM   #1
Trader Rating: 0
Default 4.8 oil leak
So i recently bought a 2001 silverado RCSB 2 wheel drive with the 4.8. While changing my oil I noticed that it has apparantly been leaking oil around the oil fill area on the passanger side head. I didnt know if there is a gasket here or if anyone else has experienced this? The oil gauge reads 60 while cruising but will go up to 80 under full throttle. What does this mean?
thanks
wahoo09goalie is offline   Reply With Quote
Old 07-08-2009, 01:24 PM   #2
Trader Rating: 10
Banned
The oil gauge is normal and someone probably spilled oil when they were filling it. If it isn't that, then the valve cover gasket might be bad, but there really isnt all that much oil up there
00ChevyScott is offline   Reply With Quote
Old 07-08-2009, 02:01 PM   #3
Trader Rating: 3
LsxCody's Avatar
Send a message via AIM to LsxCody
^ that would be my guess
__________________
00 silverado
LsxCody is offline   Reply With Quote
Old 07-08-2009, 05:01 PM   #4
Trader Rating: 19
PT's Slowest Truck
budhayes3's Avatar
Yea, the oil fill tube usually has an oily residue on it from either spillage or slight seepage from where it goes in the valve cover. I don't think that there's any gasket there, just a plastic tube that twists and snaps in. If it's not pouring out I wouldn't worry about it...nothing a can of brakleen can't fix lol, or as we call it at work, "gasket in a can"...
Your oil pressure's normal, keep on truckin'
__________________
Billy
[SIGPIC][/SIGPIC]
[URL=http://www.cardomain.com/memberpage/648999]My CarDomain Page[/URL]
[FONT=Garamond]99 5.3 Z71 RC/SB - [COLOR="Blue"]FLT Level7 65E[/COLOR], [COLOR="Purple"]Circle-D Billet 258mm 2B Multi-Disc[/COLOR], Comp 206/212 515/520 114, LS6 Springs, Harland Sharp 1.7's, [COLOR="Red"]BlackBear 02 PCM[/COLOR], 02 Injectors, 160* stat, 05 E-fans, Nelson Harness, Volant CAI w/ Ram Air, StainlessWorks Headers and !Catted! Y-Pipe, DMH 3" E-Cutout, 18" Magnaflow dumped over axle, 3.73 G80, Dropped on Gibbs 20's [B]**H/C LQ9, 4.10's, and TruTrac eventually**[/B] [/FONT]
budhayes3 is offline   Reply With Quote
PerformanceTrucks
Ford F150
Paid Advertisement
Tags
01, 1999, 2000, 2006, 48, chevy, fill, filler, leak, leaking, leaks, oil, rear, silverado, tube
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
PerformanceTrucks.net and InternetBrands, Inc. are not affiliated with the Ford Motor Company
