XR265HR in a 5.3 dyno graph and thoughts
Old 02-22-2009, 01:43 PM
  #21
9 Second Club
NicD's Avatar
Originally Posted by RandomHero
I wasn't aware of your credentials, my apologies . It's a pretty interesting topic. I may start a new thread to see what everyone else has to say. Like I said, I have no track times to compare.
As far as knock, I'm running 29* at WOT. I don't see knock until 32* or so (I'm aware of the law of diminishing returns on the matter) . I have not tried to fill up with 87 to see if it sees knock or not. Perhaps that test will happen when the local track opens up.
No need to apologize, I don't advertise for a reason and I didn't take any offense. I just share lots of information to try to help people out.
I just see no real gain after a certain amount of timing on these lower compression truck motors and don't see a big benefit to running premium in them after LOTS of time and testing.
Old 02-22-2009, 04:20 PM
  #22
PT's Slowest Truck
budhayes3's Avatar
Very nice gains, and you didn't have to give anything up down low either. Interesting about the low octane/ 26* of timing also, I'd be interested to hear more about this.
Old 02-22-2009, 05:00 PM
  #23
Fast355's Avatar
I guess it's going to vary from person to person. I'm curious to hear the opinion from people who have tuned hundreds of trucks. Speaking from personal experience I was able to run quite a bit more part throttle and WOT timing switching from 87 to 93. I don't have a ton of track time but efficiency was greatly increased. Under the same conditions I saw almost 3 mpg difference on the highway.
This is what I found on a fairly modified 5.3. Keep in mind that the high octane spark tables in these PCMs are fairly unique and work very well, even on a modified engine. This is what I found on a fairly mild 2003 5.3 build running long tube headers, LS6 cam, and 2002 LS1 engine management system/tune. The first test was on 87 octane and the stock timing map. The second test was the same engine, running 6* more timing on the high octane map and Shell 93 octane. On an engine dyno, running NO accessories, and a truck intake/exhaust setup. I honestly did no see enough difference to run the extra octane and additional advance.
--------Test1------Test2-----Difference
RPM----HP---TQ---HP---TQ--HP--TQ
2,500--139--291--141--296---2---5
3,000--172--301--173--303---1---2
3,500--208--312--209--313---1---1
4,000--250--328--252--331---2---3
4,500--290--338--291--340---1---2
5,000--324--341--327--344---3---3
5,500--340--325--344--328---4---3
6,000--344--301--353--308---9---7
Old 02-22-2009, 07:13 PM
  #24
9 Second Club
NicD's Avatar
Yea that was the part I really liked about it, nothing was really given up down low at all.
As far as the lower octane timing stuff goes I just don't usually see these 9.5:1 motors being octane limited much if at all. Meaning you can feed timing in to them at 87 octane and make just about as much power as you can with 91 octane. Just adding timing for the sake of running higher octane doesn't necessarily give you a noticeable gain when you are not octane limited. IE it may knock above 27 deg of timing on 87 but is it really making more power if it's set to 32 deg on 91 octane? Not in my experience but of course every combo is different but I am just talking in general.
Old 02-24-2009, 09:57 AM
  #25
9 Second Club
NicD's Avatar
Just a few more things....
The stock 24.5 lb/hr injectors that are in my truck are very much at their limit. I am seeing ~95% at 6300 rpm at a 12.5:1 a/r ratio. I am not really worried about any problems arising from this but I am going to be looking for some bigger factory injectors to swap in at some point. Going to the marine 44 lb/hr injectors seems like a bit of overkill but I don't really see any other injectors in the mid 30 range that would work other than maybe stock car LS2 injectors but even then those aren't the right length, etc correct?
I found my good mic last night so I will probably try and take an idle clip tonight or tomorrow if anybody is interested in what it sounds like.
Old 02-24-2009, 10:11 AM
  #26
dlt76028's Avatar
regular 8.1L are direct swap and their 31 lb
Old 02-24-2009, 11:04 AM
  #27
9 Second Club
NicD's Avatar
Ahh, but I won't have much luck finding those around here since most people don't pull them out like the vette and GTO crowd does for bigger ones. I am pretty sure I know of a couple of sets of the stock car LS2 injectors at some of the local shops that I can get my hands on for cheap, just don't know if they are a direct swap like the 8.1L injectors.
Old 02-24-2009, 11:08 AM
  #28
dlt76028's Avatar
might want to jump on these...
http://cgi.ebay.com/ebaymotors/Injec...ayphotohosting
Old 02-24-2009, 11:23 AM
  #29
PT's Slowest Truck
budhayes3's Avatar
I got my 8.1 31# injectors on ebay for less than $100 shipped
Old 02-24-2009, 11:28 AM
  #30
9 Second Club
NicD's Avatar
Yea, just looked at some LS2 car injectors and that's a no go. Only reason I wanted the LS2 car injectors is because I could take a set or two for free.
I will look in to the 8.1L injectors, thanks for that link on Ebay. Guess I just have to figure out what I really want to do with the near future and if it's worth it to get the 31# injectors or not.... cough... TVS...
Quick Reply: XR265HR in a 5.3 dyno graph and thoughts
