You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
are X/H pipes even worth putting on?? i welded an x pipe on here a while back and was just wondering if they actually do add any hp? i never felt any difference with the ole butt dyno..any one actually done a dyno test with before and after with these?
I have read a number of dyno tests on exhausts, and the general result seems to be that an h-pipe will make more midrange tq and hp than nothing and an x-pipe will make more than an h-pipe. A buddy of mine recently put a x-pipe on his car and it really seemed to make a difference from about 3000 rpms up...
If you decide to use one, go with the X-pipe. Also make sure you place it as close as possible to the engine, right after the cats and before the mufflers.
Jim
__________________
New 2008 TBSS
Black on black, leather, sun roof, AWD
1/4mi: unknown
Modifications: None at the moment....
the x-pipe will flow a little better and be more useful as far as its intended purpose IMO... the flow paths cross each other equalizing the pulse better than an h-pipe.
I'm even going to try something a little different. On my crew cab, I had the cutouts before the x-pipe and then into the mufflers, but I noticed a lot of lowend torque loss when the cutouts were open. So this time, I am going to put the x-pipe right up at the front, as close to the motor as possible, and weld the cutouts right behind them to see if this will help any. Hopefully I will see a nice medium between the gain of some low end, and gains in the upper RPM's.
__________________
Fomerly: L33Z71
2012 Silverado 1500 ECSB 2wd Z71 - Black 5.3L/6A/3.42~Stock Modded AirBox/AFE Pro Dry S/AirAid MIT/MagnaFlow #12619~SLP Tip
2007 Silverado RCSB NNBS--Greystone Metallic 4.8L-3.73 - SOLD
sounds like a good idea to me... I notice I lose a lot of tq down low with both of my cutouts open too. They are right behind the header collectors on the Y pipe... I just run a big single exhaust otherwise...
