throttle body bypass
Old 05-09-2006, 10:59 PM
Default throttle body bypass
so what exactly is the throttle body bypass, i read people having it alot but what does it do, how does it work and where do you buy or create it?
Old 05-09-2006, 11:09 PM
The TB bypass just removes the engine coolant from circulating in the TB, this is must if you live in the south. As for components go by Homedepot, or Lowes and buy a 1/8 or 1/4" (don't remember which size) splice bard and 2 hose clamps. If you want you can buy to rubber caps and plug up the TB, if you don't want dirt clogging the ports.
Old 05-09-2006, 11:11 PM
can you post picture of where all this is going on, i have the cable driven TB and i dont see where the coolant goes in an out..? a little confused
Old 05-09-2006, 11:12 PM
three83's Avatar
There is a coolant line that connects to the TB then goes out of the TB to the motor. It is designed to keep the TB from icing up in cold weather. So basically people bypass the TB by connecting the line going to the TB to the line going to the motor. Before I did the mod after driving the truck for a while the TB was very hot and after the mod there was a noticable difference in temp it was much cooler. Some say it is good for a few hp, so say it doesn't help at all. I did it because it cost all of about $4.
Old 05-09-2006, 11:27 PM
This is the best picture I have, I am sure someone else show a better pic.
Old 05-10-2006, 12:05 AM
merk7408's Avatar
I just discarded the hose from the tb to the head and connected the hose that was originally from the radiator to the tb, straight from the radiator to the head. This was after the e-fan though, so I don't know if I would have had enough slack with the stock shroud. Just another option though.
Old 05-10-2006, 12:23 AM
stone150's Avatar
if i do this will any coolant drain?
Old 05-10-2006, 12:41 AM
merk7408's Avatar
ALWAYS DO ON A COOL MOTOR. If you are going to put the splice between the two hoses you can use vise-grips or some other way to pinch off each hose before the tb, then disconnect from the tb and place together with the splice. The tb is going to spill what it has in it, but you shouldn't loose any from the motor or radiator. If you are going to try and run the hose straight from the radiator, well, just plan it out and do it quick as hell, and you shouldn't loose much either.
Old 05-10-2006, 01:19 AM
10 Second Club
04BlackGmc's Avatar
easy way is to just get a whole new hose, and dont mess around with splicing..
Old 05-10-2006, 03:36 AM
Pjstucn's Avatar
my dumb *** paid a speed shop to ship these parts to me this was before i new what was invalved, so Im only half retarded.
Quick Reply: throttle body bypass
