Would you run this motor if it was yours?
#34
Thanks- don't be fooled though on the tough spots where the gasket mated I did cheat a little with a scotch bright pad- but most came clean without needing it- it did take awhile to do this- started at about 10am cleaning surfaces and stopped at about 1:30. And still have one more head to clean up.
Note: Just have to be careful with the pad don't want to make the deck or the head surface unlevel you've have issues- those pads can remove some material when there fresh
Also wd40 can in some cases removed permanent marker off painted walls
