Won't start first try
I have a 01 Silverado with a 5.3 that looses fuel pressure with key off. Takes a few key cycles for pressure to build. I have pulled the vacuum line off the regulator and no fuel is in the line. The fuel pressure jumps to 58 with the line off. As soon as you shut the key off the pressure drops from 50ish to 0 in about 5 seconds. Any ideas?
My 99 has done it the same thing to me at least 3 times and every time it has been the pump. i never really got i to figuring out why it was happening, but there were too many other issues all pump assembly related; inaccurate fuel level signal, delayed start, and random loss of pressure. I had one pump that was providing just enough pressure for the truck to run, never thrpugh a lean code either at the end of that one's life i wasgetting ridiculously good fuel mileage....then i changed it
