won't idle, cam position sensor?
#42
Custm2500's Rude Friend
I see this originally started back in 06 you also mentioned a wireing Issue at one point.
Did the code ever go away???
If the wireing is sound and the sensor is reading the only other thing would be an issue with the cam.
check out what happened to this guy.
Help!: dtc p0343
#43
P0343 Camshaft Position Sensor Circuit High Input
Help!: dtc p0343
Help!: dtc p0343
#44
My point was that if there is an issue with the cam shaft being to long or short you may have an issue like the guy with the loose bolts.
#45
Sorry it wasnt ment to be read as you left something lose but maybe there is an issue with the cam shaft it self. after all you mentioned this code has always been there since the swap.
tweeder
09-18-2015 11:02 PM
InsaneDomestics
07-27-2015 02:42 PM
atxlt
07-20-2015 11:06 PM
Mossyoakglock
07-17-2015 08:30 AM
Suburban2500
07-14-2015 02:10 AM
