Vortex max motor mount issues
Old 08-24-2015, 05:58 PM
Registered User
Sp8s81's Avatar
Default Vortex max motor mount issues
Hello I have a 07 v-max with pacesetter headers, custom tune, cam, cold air intake I keep breaking drive side mount. I have even gone as far as replacing both motor mounts and Trans mount and still having trouble keeping the driver side from breaking at the boot! Not a fan of the clamshell mount any ideas on how to solve this issue?
Old 08-24-2015, 06:13 PM
Formerly ScreamingL
George C....'s Avatar
solid mounts or plate the stockers
Old 08-24-2015, 07:36 PM
Registered User
Sp8s81's Avatar
Any suggestions on where I could get solid mounts from? Could this be a heat issue damaging the boot over time and if so would it be a good idea to wrap the headers and or make a heat shield for the mount.
Old 08-24-2015, 07:46 PM
Formerly ScreamingL
never saw heat killing the mount
are you making any kind of power?
Old 08-24-2015, 08:21 PM
Registered User
Sp8s81's Avatar
Around 450hp
Old 08-24-2015, 08:23 PM
Registered User
Sp8s81's Avatar
It has a firm shift after beefing up trany. We added corvette servos and springs and installed z-pack clutch assembly
Old 08-24-2015, 08:49 PM
Formerly ScreamingL
Something else is up, far from enough power to break the mounts
Old 08-24-2015, 09:18 PM
Registered User
Sp8s81's Avatar
Thanks for the info George.
Im going to have it in the lift all day tomorrow any suggestions on places to start searching for the cause?
Old 08-24-2015, 09:28 PM
Formerly ScreamingL
Im worried if you go solid may crack the block
But if you look in members built items there's a guy that sells some....I made my own tubular mounts
But look for misalignment of driveline
Old 08-24-2015, 09:32 PM
Custm2500's Rude Friend
1FastBrick's Avatar
If it was used, Look for previous frame repair damage.
Quick Reply: Vortex max motor mount issues
