Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
Go Back   PerformanceTrucks.net Forums > GENERAL MOTORS SPECIFIC FORUMS > GM Engine & Exhaust Performance
Sign in using an external account
Register Forgot Password?
Register Albums FAQ Members Calendar Search Today's Posts Mark Forums Read VendorsGarageUsed CarsStore TSBs & Recalls
Welcome to PerformanceTrucks.net Forums
LinkBack Thread Tools Search this Thread
Old 09-06-2010, 08:46 AM   #1
Trader Rating: 0
dragpac's Avatar
Default turbo 4.8
a good friend of mine just put a turbo on his 2010 2wd-rcsb chevy.he also changed his tranny to a 400 turbo with a 4000 8" converter.he told me last night that it runs realy well and that it spools up to 12lbs of boost at the line with that converter.tonight he's taking it to the dyno to see what his #'s are.also he put a Z06 cam in it.should be pretty quick.
__________________
91SS454 stock block/older GM heads-cam=850demon-NX kit 353hp on motor and 515hp on 150 nos 11.09@119 W/1.49 60'
2011SBRC 2wd f150 5.0 headers,3"duals,cai,GT mustang cams,circle d converter,4.10 gears,zex kit
11.62&117.10w/150 shot and 12.62@107 w/1.77 60'NA
2013 Ram1500 2/wd rcsb silver hemi 3.92gear 6speed all stock 13.96@96
dragpac is offline   Reply With Quote
Old 09-06-2010, 10:29 AM   #2
Trader Rating: 4
they work pretty badass, look at my truck in my sig
__________________
New setup 5.3 self ported 706s, pt88 10.01@135mph on drag radials. Best sixty 1.48 60'
http://www.youtube.com/watch?v=d4ZEt5RLOUw
Cam only, stock heads 4.8L 10.79@129mph with 4l80e
http://youtu.be/a1PgnXdyKtk
Llaverito is offline   Reply With Quote
Old 09-06-2010, 11:27 AM   #3
Trader Rating: 1
foose04's Avatar
Is that 11.0 the current stock 4.8L record? (In a truck of course) I'm trying to think of who would even be second fastest.
I found this guy Kyle running 11.9 in a 4.8.
http://www.youtube.com/watch?v=hryaU...eature=related
__________________
2004 GMC RST: TMS Iron 347/S480/4l80E
Old best 4.8L/S475: 919HP/880TQ
Quickest/Fastest 4.8L Truck 10.17@134.26 (retired)
91 Eagle Talon: AWD/2.0L/Turbo/E85-10.77@136, 570AWHP Mustang Dyno (retired)
http://www.youtube.com/watch?v=yB9kDxXRLgw
foose04 is offline   Reply With Quote
Old 09-06-2010, 02:06 PM   #4
Trader Rating: 1
11 Second Club
brent1976's Avatar
What did Quik run with his tt setup?
__________________
'99 RCSB 4x4, Rex Forged 6.0l, WCCH 6.0l heads, Trick kit w/ a 76 mm, 212/218@115, Magnaflow, FLT 4l80e, Circle-D, hydro-boost, HPT,
SS 6 lug 14 bolt
brent1976 is online now   Reply With Quote
Old 09-06-2010, 05:03 PM   #5
Trader Rating: 0
dragpac's Avatar
I got a ride in the truck today.it pulls real hard after boost.and feels like 11's will come pretty easy if it gets out of the hole good.
__________________
Old 09-06-2010, 05:15 PM   #6
Trader Rating: 5
Parke10's Avatar
Quote:
dont think it ran,turbos were too busy fighting eachother for air.
__________________
Parker
2006 RCSB Sierra NBS Cammed LQ9
HPT Tuned by Jim @Cal Speed Tippin the scales at 4200 flat
WPR
Parke10 is offline   Reply With Quote
Old 09-06-2010, 05:34 PM   #7
Trader Rating: 31
Logs Look Good
Atomic's Avatar
12lbs at the line? does that sound like a lot to anyone else...?
__________________
99 z71 with some mods
Build Thread
Atomic is offline   Reply With Quote
Old 09-06-2010, 05:52 PM   #8
Trader Rating: 4
I was running 16psi, ill be trying 20psi pretty soon if stock head bolts hold
__________________
Old 09-06-2010, 06:12 PM   #9
Trader Rating: 1
foose04's Avatar
Llaverito, is that from the launch or after you roll out?
I have a Circle D triple stalled at 3200 coming but will be running a transbrake. I was told it would be up around 4k or so on the brake, so thats more then enough RPM for full boost (15psi), I have a feeling i'm going to blow the tires off it.
__________________
Old 09-07-2010, 07:33 AM   #10
Trader Rating: 4
It makes full boost on the transbrake and goes all the way up 4600 or more and the transbrake is very low to release. Im gonna change the brake and send the converter to restall it lower.
__________________
PerformanceTrucks
Ford F150
Paid Advertisement
Tags
1500, 2010, 383, 48, 48l, 76mm, banks, chevy, e85, gm, put, truck, turbo, turbo48, turbocharged
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
PerformanceTrucks.net and InternetBrands, Inc. are not affiliated with the Ford Motor Company
