Truck consuming oil and spraying out dipstick
So my truck just recently started consuming oil and spraying out the dipstick? I did some research and figured it was a bad PCV valve, but both part stores I went to say my truck doesn't have one? Is it different on an 05? I pulled the vacuum line off from the intake to back of driver side valve cover, and tried to pull the barbed fitting of the valve cover (the part I thought was the pcv valve) but it doesn't seem to wanna budge So I pulled off the valve cover and cleaned out that fitting but its still doing it any ideas? thanks.
Yes the truck has a p1sc procharger at about 6 psi. Motor has 200000 miles! I will do a compression test to see, I've just been avoiding that because it's a pain to do the drivers side with the blower. It just seems weird it would be rings cause I just had the heads off and the cylinders all looked great plus the truck isn't down on power at all. Is there anything else I can check before a compression test? I already pulled the driver side valve cover and it was super clean.
You can't really test blowby at the oil cap unless you put a latex glove or balloon over the hole and see what happens. If you actually had noticeable blowby by taking the cap off, then you'd have a major malfunction.
