Torquer v4 on 5.3?
Torquer v4 on 5.3?
I have a 5.3 chevy silverado single cab fbo with 243 heads & I'm looking to cam it I was wondering if anyone has any experience with the torquer v4 on a 5.3 I'm looking for top end power I have 4.11 gears so I need top end
Lebrown1573 (03-10-2023)
I'm just looking for something bigger then the 228R everyone has that cam wanna go a different rough but Still wanna make as much power as possible more top end is my goal
With that cam and a 5.3 you will be wasting power because you wont be spinning it high enough to take advantage of the power curve. Something a bit smaller is actually going to be faster unless you run a big stall and spin it to 7k. (Even at that I bet the HP peak is beyond 7K, at that RPM more things will choke it up) You will not be moving enough air to need a cam that big in a 5.3
I would stay under a 228/228 with 112 or 114 lsa. Much bigger you would need longtubes, ported intake, ported heads and so on to benefit. Usually under 112 LSA it is hard to pass smog. The TSP 228/228 .600/.600 112 is a great cam and I ran that in my 04 Z06 and pulls hard past 6500RPM. Also the TSP228R works perfect with a 3400-3800 stall.
Do you daily this?
Do you have smog limitations?
What are your other mods?
Do you daily this?
Yes I daily drive it although I have a mustang also so it's not my only car. Mods I have longtube headers full 3 inch exhaus intake 4.11 gears getting some 243 heads this month might mild them also have a super servo on my transmission & a possi unit
